Repair or replace
Old Mar 2, 2020 | 10:16 AM
98hotrodfatboy's Avatar
98hotrodfatboy
Originally Posted by daven9113
That's a good method. Marking a flat on the PR helps, and or moving over one flat, then tightening it down would get you back to the correct position too. I don't quite pre-load my lifters as much as you do. When I ran the Wood 6 cam, the recommended pre-load was at .142. The current slow-leakdown lifters I have and running a EV-13 cam, I'm good at .066-.073 recommended pre-load.
Are you running the Fueling lifters?
Old Mar 2, 2020 | 10:25 AM
daven9113's Avatar
daven9113
AMS Johnson-Hylift Lifters.
I'd probably be good at running them .100, but that was what they recommend as the best geometrical angle for the PRs. I'm sure it doesn't make a difference. They work nicely though.
Old Mar 2, 2020 | 05:14 PM
almostakeeper's Avatar
almostakeeper
I'm curious as to what brand of adjustable push rods I have.
The nuts are 1/2" and the flat sides on the thread are 8mm
When I re tightened, I went at each one probably 4 or 5 times to get the same spin as when I pulled em.
what are these numbers you guys are posting and how/where are you measuring.
also, the .007 shim parked under the bottom washer was not on the bike when I pulled everything, and I didn't add anything. Should I be concerned.
Old Mar 2, 2020 | 05:23 PM
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
Pictures would help.
Unless you're leaking I wouldn't worry about them at all.
Keep an eye on them for a while is my advice.
Old Mar 2, 2020 | 06:41 PM
98hotrodfatboy
Yeah a pic would help.. never seen 1/2" nuts on am adjustable.. surprised they're not tapping the tubes.. And what .007" shim you talking about?
Old Mar 2, 2020 | 06:49 PM
texashillcountry
Dirt don't hurt
Number 10 in this diagram.
https://shop.suburbanharley.com/oem-...2f%2fROCKER_/y
Old Mar 2, 2020 | 06:50 PM
almostakeeper
I'm not gonna do any more rides on her till I get in my "riding comfort zone"
The forward control pegs blow chunks. Damn near impossible to keep my shoes from sliding off, they suck. J & P has 7 1/4" fully adjustable mini boards for under 160, free shipping. Anybody know of something better/longer don't be shy.
And can I get a hell no on those mini mirrors. It's like death waiting to happen. Still searching.
Old Mar 2, 2020 | 06:54 PM
texashillcountry
Dirt don't hurt
If that stuff is made by Kuryakyn then all I can say is good luck.
I recently picked up a set of OEM mirrors that you can have it you want them.
Old Mar 2, 2020 | 06:56 PM
98hotrodfatboy
Ah yes, the seat for the lower pushrods tube seal.. it's not a shim.. The lifter blocks are not machined to accept just an o-ring... If you look closely one side is machined (well probably not machined but definitely a full flat surface as compared to the other side) which goes up to support o-ring properly...
Old Mar 2, 2020 | 07:42 PM
texashillcountry
Dirt don't hurt
I'm fully aware of that but that's what AAK is calling it.
AAK said his bike didn't have any of them in it when he rebuilt it and it seals so I told him to keep an eye on it.
