Spring start issues help
Old Apr 8, 2020 | 04:24 PM
Rijan's Avatar
Rijan
Default Spring start issues help
Hi guys need help
so went to start my 1988 FLSTC... long story short battery tender green al winter. Then tried starting would turn over once then stop. Lights work well etc... have old water acid battery noticed all holes pretty empty of water. So filled it up. I am assuming I killed this battery . So it’s plugged in for the next 2 days if still red would I be right to assume that’s what it is .
Malabo it was spitting out oils from the breather tube bit read that is somewhat normal from resting all winter... any thoughts
thanks guys
Old Apr 8, 2020 | 05:12 PM
0maha's Avatar
0maha
Odds are the battery is shot. You can pull it and take it to an auto parts store and have it load tested, or just bite the bullet and get a new one.
The oil puking is normal.
Old Apr 8, 2020 | 05:46 PM
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
Personally I like YUASA batteries.
Old Apr 8, 2020 | 05:56 PM
Rijan's Avatar
Rijan
are you talking about the Ones you have to fill?
i have on my 2009 bagger the non maintenance ones and less headache . I guess during the winter in the cold garage the distilled water I added Evaporated
Old Apr 8, 2020 | 06:36 PM
texashillcountry
Dirt don't hurt
Yep.
You fill them, let them outgas for 30 minutes to an hour, seal them, and finally put them on a trickle charger to top them off.
If you do all that the batteries will last you a long time.
BTW once you seal them you don't open them again.
AlBaron
Apr 18, 2015 01:46 PM
Monti
General Topics/Tech Tips
Jan 15, 2013 08:36 PM
BiggDogg
Mar 21, 2012 08:23 AM
Hardly Dangerous
Mar 9, 2010 07:21 PM
HeatherC
Sep 23, 2005 12:16 AM
