Just got riding the bike after i installed the original chrome nose cone and its still tapping,so that rules out the black nose cone,at this point im thinking a lifter went bad idk what else to think??
Earlier I mentioned that a sitting motor could cause a condition where the lifter will not pump fully. Very well could be the case. It just sucks that you made a change and the noise is there which would be my first suspect... A gauge would tell you a lot. Some say as long as the light goes out your good but I'm not too keen on that... It gives me comfort... Plus I think they look good...
did a oil psi check too,pressure was perfect,its gotta be a stuck lifter sounds like front cylinder the more i listen to it,is it unsafe to ride like this?
Everything inside is stock except the cam i changed it 4 years ago the bike only has 15k miles its last year for the evo 1999 ive had this bike for 7 years now had 5k miles when i bought it
I am not taking that nose cone off again im just gonna change out the lifters for now and ill see,bike does not have alot miles so cam bearing can wait for now
