What year road king
Old Jun 15, 2020 | 06:09 AM
Mike Fairchild's Avatar
Mike Fairchild
5th Gear
I have a 98 Classic. With efi. It’s great. I won’t trade mine in.
Old Jun 21, 2020 | 09:34 AM
Jbullard86's Avatar
Jbullard86
Originally Posted by EVOrider
If you find a EVO Road King with EFI and love the bike but absolutely don’t want the EFI version.....don’t say “No” to that bike.
They are relatively easy to change to a carburetor on those and not too expensive either.
I would consider 1996-1998....nice upgrades
surly you must know a cheaper way. Going through jp cycles I’m looking at about $1000 +/- to convert my 98 classic to carb.
Old Jun 21, 2020 | 10:24 AM
EVOrider's Avatar
EVOrider
Not everything has to be bought new....most of the stuff turns up on EBay. Sell the old EFI and help make up the difference.
Throw enough money at Magneti Marelli....you’d still have a 20+ year old system.
I’m still EFI here.....but when the ETS is not available anymore. Then.....it’s carburetor swap time.
Old Jun 21, 2020 | 08:32 PM
1997bagger's Avatar
1997bagger
Used CV carb and intake - a Twin Cam intake and carb will work on it. Ultima 2000I ignition KIT, comes with wiring, white wire with black tracer under right side of fuel tank is switch power. Used Pingle petcock off Ebay, Pingle fuel tank adapters. $500 if you do your homework plus carbs are the catazz on a Evo, ran both EFI and carb.
Old Jun 22, 2020 | 05:43 AM
Mike Fairchild
5th Gear
Originally Posted by Dehammer
I have a 97.
97 - 98 will have the newer frame.
The 98 will have the newer clutch basket. I've never dug into the newer ones so I can't say if it's desireable to have.
I have a 98 CI. Runs and rides great. But it is efi.
Old Jun 22, 2020 | 12:47 PM
1997bagger's Avatar
1997bagger
What flywheel did you use to keep the Magnetti & Marelli efi?
Old Jun 22, 2020 | 01:29 PM
98hotrodfatboy's Avatar
98hotrodfatboy
I I think he meant He's got a '98 Electra Glide classici/injected.. I don't see how you can make a 98 in stroker Evo motor
E-Jake
Jun 17, 2020 08:46 PM
Dan Osborne
EVO
May 30, 2020 07:49 PM
cowboyshovel79
EVO
Jul 4, 2017 07:09 PM
jmac851
Aug 22, 2009 09:07 AM
racedad00
Feb 16, 2006 10:50 PM
