I don't know for certain, however that circlip is only a retaining device, so I would expect the ring/washer underneath it to lift off. It is that ring which does the work of holding the thing together, backed up by the circlip. It may be 'stuck' to the rest of the clutch by a thin film of oil.
There is a strange ring on the back where the circlip is. How do I remove this? Just press the axel down
and it will come of? It doesn't say anything in the manual.
As mentioned that fat conical ring is an aftermarket reinforcement measure someone installed after having to replace the clutch hub when it cracked at the keyway, still have a few in repair the stash from those days, came in 2 sizes so they particular to the application. Silver and gold colors are the tell differences.
Next is it's a press fit, you'll need access to a hydraulic press or a way to make something up, I used a socket a size under as an arbor to push the hub out of the bearing & shell. I have seen hardwood like oak and some all thread used as a puller while the ring was heated with a propane torch before, extra set of hands helps this way.
Next is I would not put back together without it, those hubs were notorious for breaking why that thing was invented. Install is easy just heat the ring after the hub & shell are back together and it'll drop right into place ans shrinks tight as it cools.
TwiZted, thank you for the detailed description!
I ve ordered a press, so when it's in, I will be able to replace the bearing. And finish the job.
