Evo engine build
Old Jul 16, 2020 | 07:16 PM
t150vej's Avatar
t150vej
Originally Posted by Dacew
Thank you T150ve you understad me completely as im trying my best, its a dying skill that not many under stand lukily i am very patient and i can walk away to regroup even though i dont want to split them again i will try again thank you for the insight much respect to all....
Don't blame you not separating them again. Just something to check next time you do one - put each half in the dead centers and measure off the side of the wheel. That will tell you how much the shaft is off in relation to the wheel half. Need to do that especially on 4 or 5 piece wheels. I'll skip the lesson for now on how to correct them if they're off much.
You may already know, but just in case - there is a restrictive fitting (allen screw with a small hole) in the outer end of the pinion shaft. Remove that before you put it in the dead centers. Depending on the angle of the centering points, leaving it in will make readings difficult and inconsistent. And DO NOT loose it or forget to re-install when you're done.
Old Jul 16, 2020 | 07:19 PM
Dacew's Avatar
Dacew
6th Gear
Default Evo engine build
Ok will do ill keep you posted
Booberjinx
EVO
38
Feb 6, 2023 12:18 PM
1997bagger
EVO
16
Jul 21, 2011 09:24 PM
saweet96
Exhaust System Topics
Nov 30, 2006 02:14 AM
KBFXDLI
Sep 20, 2006 11:20 PM
