Timken bearing question.
Old Jul 16, 2020 | 07:08 PM
95fxstc's Avatar
95fxstc
Default Timken bearing question.
My 95 fxstc has an aftermarket front wire wheel. I just purchased a ride right wheel for the front, wire also just wider. The wheel on the bike now has no washer or spacer to set bearing free play just the internal spacer. The new wheel is the same way. Is this because they are aftermarket wheels or are they just missing. The wheel on the bike has been on there for 20 years no problem.
Old Jul 16, 2020 | 07:28 PM
t150vej's Avatar
t150vej
Not unusual for wire spoke wheels. They had different length spacer tubes available and often as not, didn't require the special spacer washer or shims. Just use a piece of all thread or your axle with extra spacers to check the end play of the bearings before you install it.
Old Jul 16, 2020 | 08:44 PM
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
Another option is PO got a longer center spacer and cut it to fit exactly.
Not something I'd bother doing but I know someone who did.
Rtl4042
Wheels/Tires
Jun 20, 2017 09:50 AM
Ozark Joe
EVO
Jan 4, 2017 12:39 PM
Curtis36j
May 3, 2016 04:10 AM
cardboard
Wheels/Tires
Nov 14, 2010 04:06 PM
Rickr01
Aug 13, 2009 11:56 AM
