Starter issues
Old Sep 14, 2020 | 11:43 PM
Zdollar's Avatar
Zdollar
Default Starter issues
What’s up guys, got a 90 fxr that’s giving me some starting issues and honestly it’s got me stumped. So here’s the run down. I press the starter button, and the solenoid engages about half way, sending the jack shaft out, then my bike loses all power for about 5 seconds and reboots. Meaning lights shut off and all then it powers itself back up. There is a new lithium battery, just rebuilt the solenoid, and tried a couple different relays I had lying around. I’ve bench tested the starter and everything works as it should off the bike. Testing the blade connector that engages the solenoid it holds power when disconnected and I press the handlebar switch. Arcing the posts still cranks the starter over. Seems to only be losing power when the solenoid is engaged.
Old Sep 15, 2020 | 03:43 AM
guido4198's Avatar
guido4198
Have you tried another battery that comes off a bike that is NOT having "issues"..???
I fell into the "can't be the battery...it's brand new" trap a few years back. Ended up with a bunch of new parts on the shelf before discovering that my brand new battery was the problem.
Just a thought.
Old Sep 15, 2020 | 06:11 AM
RANGER73's Avatar
RANGER73
Check your main circuit breaker. Not sure on the 90, my 94 is on the front of the splash guard.
Sound's like it's weak and tripping, they're self resetting. That would explain the loss then reboot of power.
Old Sep 15, 2020 | 06:18 AM
Architect's Avatar
Architect
Sorry to say, 9 out of 10 of these threads, it is the battery. Can you borrow a known good battery, might save you a bunch of time. Good luck.
Old Sep 15, 2020 | 07:18 AM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
Dead batteries are smart, they don`t want to be changed, so they like to make it look like some other component is at fault...
Old Sep 15, 2020 | 08:28 AM
Racepres's Avatar
Racepres
Is there an Echo in here????
Note... New means Nothing anymore... Tested Working is where it's at...
Old Sep 15, 2020 | 08:33 AM
Dan89FLSTC's Avatar
Dan89FLSTC
When testing the signal circuit (the green wire between the starter relay and the solenoid) for voltage, it should still be connected so that the circuit is under a load (actually, all circuits should be tested while under a load).
Leave the wire connected, and read the voltage when pressing the start button.
You can put the probe of your meter into the connector at the relay green wire terminal, or slide the connector off just enough to expose the blade terminals on the relay.
If you can`t get at the relay connector, you can make up a little jumper wire which allows you to keep the circuit connected and gives you a place to connect your voltmeter:
Jumper wire installed
With this jumper wire installed, you can test the signal circuit while it is under a load.
Old Sep 15, 2020 | 09:18 AM
Zdollar's Avatar
Zdollar
I did this as well and it dropped from 13.x volts directly to 0 when tripping the breaker
Old Sep 15, 2020 | 09:20 AM
Zdollar's Avatar
Zdollar
Sounds like I will be taking my battery to HD to have them load test it unless I can find someone willing to let me put their battery in for a sec
Old Sep 15, 2020 | 10:13 AM
Dan89FLSTC's Avatar
Dan89FLSTC
I think any auto parts store will test it for free.
