Starter issues
Old Sep 16, 2020 | 04:19 PM
  #101
Zdollar's Avatar
Zdollar
I already said, unless you explain exactly what you did, the description is mumbo jumbo to me, sorry.
Fall back a bit and try this:
Disconnect the green wire from the solenoid.
Press starter button, exactly what happens?
the starter relay clicks, and that is all
Old Sep 16, 2020 | 04:20 PM
  #102
Zdollar's Avatar
Zdollar
Has the starter ever worked properly with this new engine?
No it has not, at least not in my bike
Old Sep 16, 2020 | 04:24 PM
  #103
Beemervet's Avatar
Beemervet
Originally Posted by texashillcountry
FWIW when something goes wrong with my bike right after I changed something on it the cause is usually something I did.
Time after time..
Old Sep 16, 2020 | 04:33 PM
  #104
Beemervet's Avatar
Beemervet
I suggest you slow down, do the baby steps as suggested by Dr. Hess and Dan. They can only work with info that they get from you, and they are good at doing this.
Patience grasshopper.
Old Sep 16, 2020 | 05:20 PM
  #105
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
The starter has never worked with this engine, so another thing must be determined...
Is the engine mechanically sound, can it be rotated?
Old Sep 16, 2020 | 06:38 PM
  #106
Dr.Hess's Avatar
Dr.Hess
OK, the resistance of the solenoid doesn't seem too far out of line, although that's 30 amps. Like I said, an ammeter in series would be helpful.
Put the volt meter across the battery, then push the start button. When your "breaker trips," what's the voltage across the battery?
Old Sep 16, 2020 | 09:51 PM
  #107
Zdollar's Avatar
Zdollar
should be, I can turn it by hand with the plugs out, but right now the jack shaft is removed so there is no resistance from the primary drive on the starter motor
Old Sep 16, 2020 | 09:56 PM
  #108
Zdollar's Avatar
Zdollar
I’ll get the anmeter reading tomorrow when I’m back with the bike, and I don’t believe the breakers to be tripping. I believe it was the built in breaker in my battery. I have a lithium smart battery so it looks to be a safety feature when the battery is shorted out to prevent it from becoming a homemade bomb. I put a stock HD battery in for the time being until I get this sorted out. With that being said the power is still being drawn or shorted since it does shut all of my lights down just the same, but they immediately power back on when the connection is broken.
Old Sep 16, 2020 | 09:59 PM
  #109
Zdollar's Avatar
Zdollar
Speaking with my buddy who’s a metric tech and refuses to learn or have anything to do with Harleys, he believes there is a power source shorting to ground based off the knowledge that the primary has power. So with that being said does anyone have a suggestion on what wires could distribute power to the main ground if I had improperly attached something
Old Sep 17, 2020 | 12:01 AM
  #110
t150vej's Avatar
t150vej
Lots of really good advice and patient help, but with 3 pages in 2 days.... for crying out loud, Lol
Been a very long day and I may have missed something trying to read thru it all, but have you disconnected the C terminal to load test the coil winding in the solenoid? (there's 2 sides of the winding)
Both sides of the solenoid coil winding somewhat ground thru the armature/brushes until the main contacts hit, then the pull-in side has (+) where it did have (-) and the other end of the winding supplies the ground. The "green wire" as everyone calls it feeds to the center of those windings and is the only (+) to the hold-in side of the solenoid. Hence the dreaded click of those new fangled starters when the windings go weak....
C terminal:
My other book isn't here and it'll gimme headache trying to type it all out. I'll post a photo tomorrow. Real simple test, just need 3 wires and a battery and disconnect everything on the starter except ground cable ....
PS....
I'm gonna assume you didn't break any insulators on re-assembly, and when you had the solenoid apart to rebuild, there's a ball on the end of the plunger return spring in the back of the main shaft, any chance you "misplaced" it during all that? If so, that'll cause all kinds of witches to appear... # 12
