Starter issues
Old Sep 16, 2020 | 01:49 PM
  #91
Zdollar's Avatar
Zdollar
And after that occurrence the starter relay will no longer click, instead it’s more of a buzz. Put in another relay I had and I’m getting the same buzz.
  #92
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
I just replaced the original starter on my `89 Softail, the pull in coil was intermittent. All voltage drop checks were good, the only thing left was the solenoid pull in coil was kaput.
Old Sep 16, 2020 | 01:51 PM
  #93
Dan89FLSTC's Avatar
Dan89FLSTC
Deleted, misread post...
Old Sep 16, 2020 | 01:53 PM
  #94
Zdollar's Avatar
Zdollar
Unplug the small green wire from the solenoid, does it still buzz?
no it clicks when unplugged
Old Sep 16, 2020 | 02:06 PM
  #95
Dan89FLSTC's Avatar
Dan89FLSTC
Originally Posted by Zdollar
then let’s make sure I performed your test right, what am I supposed to be testing the resistance on
Between the small terminal on the solenoid and the body of the starter.
Old Sep 16, 2020 | 02:11 PM
  #96
Zdollar's Avatar
Zdollar
00.4 on the 200 ohm setting
Old Sep 16, 2020 | 02:37 PM
  #97
Dan89FLSTC's Avatar
Dan89FLSTC
I think .4 ohms is a good reading. I just tested a spare starter in my garage and got the same reading.
But, I don`t think it would be a bad idea to remove the solenoid cover and must have a look around inside just to be sure everything looks hunky-dory....
Push that plunger in by hand and make sure it moves ok. The first time you push it you will feel some extra resistance, as the pinion gear lines up with the ring gear.
Of course, disconnect the negative battery cable first.
Old Sep 16, 2020 | 02:49 PM
  #98
Zdollar's Avatar
Zdollar
everything looks good in there which throws me off. Like I said previously, everything works great, 100% of the time when it’s not grounded out on the bike
Old Sep 16, 2020 | 02:54 PM
  #99
Dan89FLSTC's Avatar
Dan89FLSTC
I already said, unless you explain exactly what you did, the description is mumbo jumbo to me, sorry.
Fall back a bit and try this:
Disconnect the green wire from the solenoid.
Press starter button, exactly what happens?
Old Sep 16, 2020 | 03:34 PM
  #100
Dan89FLSTC's Avatar
Dan89FLSTC
Damn and while I’m realizing I’ve left out some important information here’s some more. All of this started happening after swapping another motor into my bike. Old motor lost all compression in cylinder 1, my buddy had a motor that was rebuilt around a year ago and never installed so I took it off his hands instead of rebuilding mine since it made more financial sense.
Has the starter ever worked properly with this new engine?
