Recommendation on rocker box gaskets, 1997 EVO
Old Sep 17, 2020 | 05:38 AM
GOGOBECK's Avatar
GOGOBECK
Default Recommendation on rocker box gaskets, 1997 EVO
I’ve got an oil leak between the rocker box and head on the rear cylinder.
I have a HD top end gasket kit (PN : 17040-92), these are 2006 vintage. The rocker box gaskets are the metal type.
Should I use the moco metal gaskets, or purchase a set of something else?
Old Sep 17, 2020 | 06:55 AM
Architect's Avatar
Architect
Stock gaskets lasted since 1997, should be good for another 23 years. I use MoCo for gaskets, good luck.
Old Sep 17, 2020 | 06:57 AM
ClifWideGlide's Avatar
ClifWideGlide
And make sure once you got it apart to check the flatness of the three pieces. If they are warped they need to be replaced.
Old Sep 17, 2020 | 09:32 AM
eighteight's Avatar
eighteight
NLA from the Moco ( Obsolete)
hard to find
Old Sep 17, 2020 | 10:41 AM
t150vej's Avatar
t150vej
You won't find a better gasket for the lower rocker housing than the OEM coated metal ones. Use them.
And that goes for the rocker cover rubber gaskets as well. OEM fits perfect every time. They're a tick thinner than most aftermarket and softer too, making them re-usuable more often than not (if they aren't terribly old)
Old Sep 17, 2020 | 06:37 PM
beardo's Avatar
beardo
Got the same kit part number a few months ago. Nary a leak to be found from the rocker boxes. I was skeptical also. Glad I did. 95% of my Evo leaks are sealed up. 1997 FXD.
Old Sep 17, 2020 | 09:25 PM
ROCKOUT Rocker Products
Sponsor
I bitch at the MoCo for countless things but one thing they get right is gaskets... none better
For ROCKOUT information & purchasing please click HERE For all Twin Cams and Evo Big Twins & Sportsters
__________________
NO, they DON'T all do that!
Also on amazon.com...
Old Sep 18, 2020 | 08:25 AM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
I recently replaced my old `89 rocker boxes with new oem parts, about 2 months ago.
I would call the dealer again and make them work a bit to find you a set. Any year from 92 up will work.
The lower gaskets are metal, the upper gaskets appear to be Teflon or Delrin (white material), they are not like the old rubber gaskets that were sometimes so out of shape that they had to be gooped in place.
With the new gaskets this job is no longer a PITA.
Old Sep 18, 2020 | 09:37 AM
98hotrodfatboy's Avatar
98hotrodfatboy
I've ever only used Cometic gaskets. And never had an issue even with a stroked Evo.. lot of back pressure there in the case more so than in a stock Evo.. No problems..
drm1978
EVO
Jun 6, 2020 01:34 PM
MxNut
Jun 22, 2019 09:35 PM
harleylay
Mar 9, 2011 01:00 PM
Stoker234
Mar 4, 2010 02:43 PM
geargrinder
Exhaust System Topics
Jan 11, 2008 06:02 PM
