1994 Dyna FXDL
I know your past this point, but just as a reference for others:
As far as front and rear mounts go, all you need to do is loosen the two front and rear allen/socket head bolts about a 1/4 inch each. They are the bolts that go from the frame to the actual mount. Not the bolts that go from the mount to the engine or trans.
The two front ones are easy to see and probably chrome. The two rear ones are a little harder to see and are tucked in at the area of where the swing arm meets the trans. Both the front and rear use a 5/16 allen wrench. Loctite blue when tightening back up.
Just a few wild guesses like: worn rubber engine mounts, previous removal and reinstallation of the exhaust putting torque on the engine or trans, the rear wheel is attached to the swing arm and the swing arm is attached to the transmission, top engine alignment mount previously adjusted...did the factory assemble the engine and trans to primary with no weight on the trans (like swing arm or rear wheel)? I have no idea, just listing some variable/possibilities. Remember, the engine is a rubber mount, not a solid mount.
Bottom line: a cracked inner primary sucks and is expensive. If the manual says "loosen" then I loosen. Same thing with the broken lip at the big O-ring on the engine...it sucks. Once everything is loosened, the engine and trans move around really easy, and when tightening up the inner primary bolts, then the engine to trans, then the rubber mounts to frame in sequence like the manual again describes, you know you have done your part and are not putting any torque or stress on that inner primary.
Now I have entered Bizarro world.. I finished the project this afternoon and wanted to go for a test run. While tightening the battery tray jacking bolt I noticed sparking.. I thought the negative cable nearby was arcing so I inserted some rubber hose as a temporary fix thinking the sheathing was damaged. I then resumed tightening the bolt and a large spark was generated and the bolt turned cherry red! I carefully removed the battery. What in Sam Hill could cause this? I installed the new starter and the ground cable is secured via the starter motor bolt.
Jacking bolt and negative cable
Battery tray jacking bolt
Just put a flat piece of vinyl, plastic, rubber or whatever in between the battery tray and the boot of that hot lead (to isolate) until you make the battery connections and draw up the battery and tray using the jacking bolt in your pic. Once you look at that black rubber boot you will see what I mean. There will be a cut in it if that is what your problem is. Mine did the exact same thing.
The permanent fix is to replace the boot and put some black foam tape on the underside of the battery tray covering that sharp metal lip.
Sealed with black Permatex
Tire spoon
