Pushrod adjustment done? Still spin by hand?
Old Nov 6, 2020 | 11:44 AM
Super Glidester's Avatar
Super Glidester
Originally Posted by Adam76
Thanks. Not sure why that would be though? They are fresh new lifters and have been soaking in oil for a few days before installing them.
Should I back the PRs all off, let it sit overnight and start again? Not sure what difference that would make though?
Yeah they need to pump up with oil pressure,soaking them primes them so they arent dry on startup.
Old Nov 6, 2020 | 12:48 PM
johnnyjellybean's Avatar
johnnyjellybean
You're only asking for problems cuz what if it doesn't bleed down? .
LOL Why wouldn't they bleed down? They're not solids!!
Of course you have to walk away for about 20- 30 minutes. They WILL bleed down and until the PRs spin , you don't turn over the motor!
Let me say this... the guy I got this tip from owns a Harley performance/ machine shop in Montreal named NTC machine shop. He does a LOT of motors. Today, I started my 106 twinkie after pulling the PRs out to chamfer the tops and bottoms of the upper exhaust PR covers since the Woods .650 lift cams make the PRs bang against the inside of the upper covers. I pumped up the lifters, adjusted and made sure the PRs were spinning while on the centerlobes and when I started the bike there was not a single tick. I'd rather have that than waiting for the ticking to go away while the PRs are banging off the lifters and rockers until the lifters are full of oil!!
Old Nov 6, 2020 | 01:01 PM
98hotrodfatboy's Avatar
98hotrodfatboy
Because not all lifters had the same bleed down rates and who the f*** wants to wait 20 to 30 minutes.. I know I don't...
AndAnd not only that some of these guys are novices so they don't even know if the lifter bled down or if they raise the valve so why take that chance...
Old Nov 6, 2020 | 01:03 PM
johnnyjellybean
Talking
Ahh!! You're not a beer drinker I see!
Old Nov 6, 2020 | 01:05 PM
WP50's Avatar
WP50
The few times I have been around a top build with lifters and cam( 3 of my own).
2 had adjustable push rods the rest did not.
Each one took 10 to 20 min. each run time for the lifters and valve train to quite down
WP
Old Nov 6, 2020 | 02:46 PM
fireman64's Avatar
fireman64
Not to hijack thread but is the intake shorter then the exhausted pushed ?
Old Nov 6, 2020 | 03:24 PM
98hotrodfatboy
Yes...
Old Nov 6, 2020 | 05:38 PM
Adam76's Avatar
Adam76
Do not attempt to readjust. I never pump up my lifters before I go to set the preload.. You're only asking for problems cuz what if it doesn't bleed down? So you got a fully pumped up lifter and you set it to .140" pre-load... Smack there goes the valve into the piston... That's why they want you to wait 20 minutes or so, so it does bleed down. The fact that it bled down as you adjust is not an issue.
That happens all the time with mine and I never have any issues.. Sometimes though it takes more than a minute for the lifter to pump up when started.. Actually it can take several minutes, so don't be surprised but don't go crazy on the RPMs either... 1500-2000 rpm is sufficient..
Originally Posted by daven9113
Adam76, keep doing what you are doing. You have adjusted the PRs correctly. The rear lifters were not fully filled with oil, but you did the adjustment correctly. Your oil pump is already primed, since you only did a top end and cam upgrade. Once you start the engine, the lifters are fed oil right away.
Thanks for the reassurance guys. All makes sense now. 👍
Really appreciate the advice.
Cheers.
Old Nov 7, 2020 | 02:04 AM
Adam76's Avatar
Adam76
Yes...
Hey 98, just out of curiosity - when buying a set of EZ install PRs, are they all same length? because you adjust each one to fit accordingly anyway?
Or do some manufacturers of EZ install PRs still make the exhaust ones longer than the intakes ? (I didn't check mine for any differences in length)..
Old Nov 7, 2020 | 04:57 AM
98hotrodfatboy
I believe you're referring to the quickies. And I'm not sure cuz I've never used the quickies.. I just use regular adjustable pushrods and yes they are different lengths intake to exhaust..
