New to me evo
Old Dec 3, 2020 | 02:53 PM
  #31
Ropestringer's Avatar
Ropestringer
Originally Posted by 0maha
If you're going to be pulling the heads, do the gaskets now. You'll be 90% of the way there anyway.
Yes, if the heads come off then I'll definitely do the base gaskets. Right now I'm trying to decide if I can do everything that I want to do to the engine this winter. If I can't then I might just put a cam in when I change the inner bearing and let the base gaskets leak until next year.
Old Dec 3, 2020 | 03:25 PM
  #32
t150vej's Avatar
t150vej
Originally Posted by Ropestringer
..... I have noticed that I have a base gasket leak. I see oil and tiny bubbles coming out of the rear cylinder base....
Something to consider - if it's leaking that bad rather than seeping, there's an even chance it either is, or will soon be developing a head gasket leak. On a stock engine that is sometimes the result of, or will always result in, a cylinder stud issue. So don't put that off too long since it's already blowing bubbles.
Don't panic though. If you do the work yourself you could possibly get by with about $150 in gaskets, and $230. in parts. (cam, bearing, rings). You'll probably get a long laundry list of things you "oughta" do on this forum, but that's a base dollar figure for a starting point.
Old Dec 3, 2020 | 03:33 PM
  #33
Ropestringer
Yikes! More food for thought.
Old Dec 3, 2020 | 03:37 PM
  #34
t150vej's Avatar
t150vej
Forgot to mention... if the compression checks good, you can remove the cylinders without the pulling the pistons. Will cost you a couple bucks for wrist pin locks, but save you the cost of rings. There's a lot more to it all but again, that's you're starting point...
Old Dec 3, 2020 | 03:45 PM
  #35
t150vej's Avatar
t150vej
And I thru it all, I forgot cost of lifters....
swampking
Aug 23, 2019 07:32 PM
traildog
EVO
34
Mar 11, 2016 06:37 AM
98flhrci
Evo Era Parts
Jan 15, 2015 12:58 PM
Mac-1983
Jun 28, 2011 06:56 AM
medic2980
EVO
Aug 20, 2008 07:23 AM
