First Evo Build
Cam shaft selection.
I've been reading and rereading this post on cam numbers: https://www.hdforums.com/forum/engin...and-2-a.htmlin
The bike came to me with a Screaming Eagle 406 in it. I was happy with the way it ran but I would like to lower the RPM range a bit while taking advantage of the increased compression ratio and mild head work that's being done. It did OK off the line and when the cam came in it was noticeable, and pulled well.
I'd like something that comes in a little earlier but doesn't run out of steam too early.
I've compared the numbers on the SE406 to the Wood W6 and several other cams on the chart on the Nightrider web site. I'm concentrating on intake closing, lift, duration and lobe centers pretty much in that order.
Looking at some of the numbers I think the Redshift 560 should be between the 406 that I have and the Wood W6.
Looking at other numbers I'm afraid it may be too low of an RPM cam for what I have in mind. I'd like the power band to be from 1500/2000 up to 4500 or higher if possible.
Any input on the Redshift 560, or cam selection in general, is welcome.
I mentioned the SE406 because it's what I have to compare things to. I'd like to lower the RPM that it comes in a bit. I'm going on memory, if I had known the bike had an upgraded cam I would have made note of where the power was. I seem to remember it was around 3000 RPM and up. I felt it most when accelerating up on ramps.
I let myself be talked into the Ultima crank and justified it to myself with the thought that the shop is warrantying the build.
I hope to end up around 10.5:1 compression. We're starting with 10:1 pistons and the shop is doing head work, springs and are ready to clearance the case if need be for the cam I select.
I am clear that I want the power around 3000 RPM, freeway cruising speeds. That's what I'm trying to pick a cam for. The shop owner was talking about more top end cams and I told him the same thing.
As I mentioned in my prior post, I'd really like the power from 1500/2000 up to 4500 or higher if possible.
That SE406 cam was a high duration low lift cam that needed RPMs to get it going The w6 should come in around 2700 and go all the way up to 6,000 RPM It's a great cam.. They even make the high lift version the W6H if you're getting the head works you might as well go with that..
I did look at the specs again on the Redshift 359, it says it's 2200 to 6000. I can't find a Redshift 360 for sale, maybe they grind them when an order comes in.
Thanks for the help!
I completely understand not getting involved in this type of discussion. I did mention it's probably controversial.
I appreciate the info on my present cam. It does have SEH-1 stamped on it, as well as 406. The chart on the Nightrider website doesn't list a SEH-1, it's listed as a 406.
I've run 3 different ones over the years and will stick with bad review of them even if the cam spec page does list slightly different specs...
