snafu rebuilding 41mm forks
Old Feb 22, 2021 | 09:49 PM
sparky0496's Avatar
sparky0496
Unhappy snafu rebuilding 41mm forks
First off been along time since I last posted just been lurking in the background reading and learning! thanks so much for all information! So my question is I might have made a mistake yesterday while rebuilding front forks..... I did not follow directions very well I accidentally put the top bushing in before inserting the rod into the bottom of fork. Now my quandary is how to remove that bushing??? Any advise greatly appreciated in advance!
85 fltc in referb mode
Old Feb 23, 2021 | 07:16 AM
Crashone's Avatar
Crashone
Are you saying that if you look into the lower leg the bushing is stuck in there? If so take a metal rod and bend the end 90-110* and work it out with that. If I'm off base disregard.
Old Feb 23, 2021 | 08:04 AM
Schex's Avatar
Schex
Try turning the lower upside down and squarely hit on a wood block or something that won't damage anything, it shouldn't be too tight in there.
Old Feb 23, 2021 | 10:51 AM
sparky0496's Avatar
sparky0496
Thanks guys however it’s the top bushing. Not the one attached to the rod end
Old Feb 23, 2021 | 12:47 PM
Schex's Avatar
Schex
Maybe head to Autozone, the loan-a-tools should have a 2 or 3 jaw slide hammer puller set, or even a blind hole puller, should have some of the bushing protruding and be able to get under it, be careful by the seal area, don't want to scratch it there and cause a leak on the seal OD.
Old Feb 23, 2021 | 08:44 PM
chopper_man's Avatar
chopper_man
How deep is it? Blind bearing puller comes to mind.
Old Feb 23, 2021 | 09:06 PM
sparky0496's Avatar
sparky0496
Thanks all for the help! I panicked last night and forgot all about the tools previously mentioned. Tried blind bearing puller no go then borrowed a 2 legged puller worked like a charm. So now everyone knows from my mistake how to read schematics first then how to fix said snafu....
85 fltc in rebuild process
Old Feb 24, 2021 | 05:12 PM
Mountainkowboy's Avatar
Mountainkowboy
That's one of them things that you will never forget now........I've learned most everything the hard way.....lol. Makes for a wonderful memory.
V-Twins & Bowties
EVO
22
Sep 13, 2024 07:46 PM
memphisharley
Feb 11, 2018 11:48 AM
tattoofever
May 21, 2013 07:18 AM
DougYITBOS
Aug 8, 2012 09:37 AM
davescreation
Mar 25, 2010 09:28 PM
