Dot 5 brake fluid quick answer needed
Old Apr 23, 2021 | 03:28 PM
JustDave13's Avatar
JustDave13
Originally Posted by t150vej
Since this thread turned into a borderline "oil thread" check out post #1 and #2 if you have what I call "unauthorized" brake parts on your bike. Pretty good read actually....
https://www.hdforums.com/forum/dyna-...e-brembos.html
And I'll have to take back what I replied to justdave in post #9 on this thread.
No worries, I was under the impression that the OP was experimenting with different types of brake fluid for his bike and I freaked out about it.
Old Apr 23, 2021 | 03:36 PM
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
Originally Posted by GOGOBECK
At a friends place to help flush his brakes... he has already used 5.1 instead of Dot 5.
can we just flush with Dot 5?
Just out of curiosity what vehicle is your friend changing the brake fluid on?
As others have said use what the vehicle calls for and don't mix I was just wondering what he/she was working on.
Old Apr 23, 2021 | 03:44 PM
t150vej's Avatar
t150vej
Considering the volume and speed of responses, you (and I) were not alone in freakin'
Old Apr 23, 2021 | 03:46 PM
mike131's Avatar
mike131
Exactly correct t150vej dot 5 compresses and Dan is rate on the money they don't play well with each other, and JustDave mine is Gold!! LOL just messing!!!, I have no further comments its all been covered here!!
Old Apr 23, 2021 | 04:06 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
I`ve been in the mechanics game so long....my license has Orville and Wilbur's pictures on it...
Old Apr 23, 2021 | 04:09 PM
mike131's Avatar
mike131
LMAO that's experience DAN!
Old Apr 23, 2021 | 04:16 PM
GOGOBECK's Avatar
GOGOBECK
The bike is an ‘03 Ultra... no anti-lock and calls for dot 5. He’s the original owner and with 70k, I suggested he flush the brakes. He mistakenly picked up dot 5.1 fluid.
He had only done the front brakes, when I showed up and he was complaining that he couldn’t get them to firm up. I noticed the container, knew enough to know it wasn’t the right fluid and I started this thread.
We drained the 5.1, used a compressor to “gently” blow out the fluid from the calipers to the master cylinder as recommended by drhess and wpo, then we flushed the system with “Heet” (stuff smells like alcohol) gently blew the Heet out, then flushed it with about 10 ounces of dot 5... the front brake is now good and firm.
I appreciate all the excellent and fast responses from here.
Old Apr 23, 2021 | 04:28 PM
Uncle Larry's Avatar
Uncle Larry
Yeah, far as I know, no ABS system uses DOT 5 because it will compress more than glycol based fluid - freaks out the computer I reckon. Harley went to DOT 4 on ABS bikes. Dot 5 is good on tactical vehicles and bikes since it doesn't absorb moisture. But that's a double edge sword - if you do get water in the system, it'll lay in the low places and corrode...
And yes, best to always go with whatever is stamped on the master cylinder....
...and it aerates ( foams ) too under ABS cycles
Old Apr 23, 2021 | 04:37 PM
Uncle Larry
What do I know with 30 years of auto repair experience. If that guy's truck had ABS he would have really been screwed.
OP use the fluid the bike calls for, my evo called for DOT 3 my TC calls for DOT 4. Don't mix your fluid and flush the system with what's required.
I got mine in 1975 ... You'll have to take my word for it though ... That was way back when and the patch and certificate read NIASE . It was about that time that Michigan went to requiring certification ... My brother and I took the test at the local armory and we were on the news that evening :>)
Old Apr 23, 2021 | 06:30 PM
Dr.Hess's Avatar
Dr.Hess
I have two mechanic's certificates. One for radio, sort of the Queen license (good for everything but aircraft at one time,) 1st Class Radiotelegraph, now renamed to Radiotelegraph, and then one for wrenchin' on people.
