Dot 5 brake fluid quick answer needed
Old Apr 23, 2021 | 12:42 PM
GOGOBECK's Avatar
GOGOBECK
Default Dot 5 brake fluid quick answer needed
At a friends place to help flush his brakes... he has already used 5.1 instead of Dot 5.
can we just flush with Dot 5?
Old Apr 23, 2021 | 12:55 PM
t150vej's Avatar
t150vej
NO. DOT 5.1 is more like DOT 4 - glycol based, rather than silicone which is DOT 5.
Old Apr 23, 2021 | 12:58 PM
JustDave13's Avatar
JustDave13
DOT 5 is silicon based and will eat up the rubber in your brake system.
Old Apr 23, 2021 | 01:00 PM
chopper_man's Avatar
chopper_man
Needs to be flushed with denatured alchohal.
SirHarley's Avatar
SirHarley
Flush out completely with the recommended fluid, and fill with the recommended fluid, and re-bleed. Your brake system will be happier for it, and you will never do that again. (I know, you were just asking for a friend) There should be no permanent damage.
Old Apr 23, 2021 | 01:01 PM
CoolBreeze3646's Avatar
CoolBreeze3646
Maybe, depends on how much DOT 5 you have, but you have to be sure you got ALL the DOT 5.1 out of the system. The safe bet would be to flush the system with Isopropyl Alcohol air dry (with an air gun) and proceed with flush and bleed with DOT 5.
Mixing DOT 5.1 & DOT 5 will cause the fluid to jell and you will have a mess.
Old Apr 23, 2021 | 01:04 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
The problem is that when DOT5 is mixed with DOT3, 4, or 5.1, it will turn to a gel.
Last edited by Dan89FLSTC; Apr 23, 2021 at 03:52 PM. Reason: incorrect information
Old Apr 23, 2021 | 01:06 PM
JustDave13's Avatar
JustDave13
When I was in the Marines all of the tac vehicles used DOT 5. I remember one guy puting DOT 5 in his pov. 1500 dollars later he got his brakes repaired, all of the rubber components were swollen and to be replaced.
Old Apr 23, 2021 | 01:08 PM
t150vej's Avatar
t150vej
No, silicone brake fluid is a lubricant and preservative to brake parts. RTV on the other hand.. the curing agents in most of it will attack certain types of synthetic rubber.
Correct (and by the book as well)
Absolutely !!!!
Old Apr 23, 2021 | 01:14 PM
Dr.Hess's Avatar
Dr.Hess
DoT5 won't hurt rubber, but the crud it turns into if mixed with 3, 4 or 5.1 might.
Flush the whole system, denatured alcohol will work (sold as "HEET" at auto parts stores,) or brake cleaner, then hit it with the air hose for a while and it will be OK. Brake cleaner will be a lot harder on rubber parts than the denatured alcohol, which is Ethanol (i.e., "drinking alcohol") mixed with enough Methanol to kill you if you drink it, so, you know, you won't be drinking it. I have changed several DoT3 clutch systems to DoT5 this way and had good results. And I use that MilSpec DoT5 fluid in the gallon jugs. Cheaper that way.
