I have a 90/90/21 shinkco 777. And it’s wanting to raise up at the tips of the tread patterns. I’m running 32 in air pressure. Do I need more air pressure to stop this from happening
We need more info like what yr and model?If its stock, what does the manual say for correct tire pressure?For example: I run 38 in front and 40 in the rear on my FLT.
My bike is a Lowrider 1340 evo and my tire is a shinkco 90/90/21. I’ve got 32lbs in the front now and it’s curving up the tips of my tread patters. I weigh in at 160lbs. The bike is suppose to be a 96 but my engine is off of a 85 wide glide. And the frame is not a Harley frame. But the Harley shop knew the individual’s name and said it was a great frame. And the engine is way above stock. But the tire is my front tire that is in question. I’m running 37 in my back tire and it’s a 16 Michelin. Niether are stock. My title says 96 and my engine and train are from a 85 wide glide.
Hey Robert...Welcome aboard.
I don't know anything about Shinko Tires....never ran one. My bike is an FXRS, similar model to yours, not a Sporty, not a bagger.
Not sure what this means: "....it’s curving up the tips of my tread patters." But if what you're describing is what is called "cupping" then the remedy is typically to increase air pressure.
For reference, I'm currently running a Dunlop American Elite on my FXRS. I keep 32 psi in it, and at 16,000 mi (so far...) there's no evidence of cupping. Shinko's may need more air pressure.
Last time I replaced my tires I emailed the manufacturer(Pirelli) and gave my info and what there recommendations were. They told me 36-40psi on my front and 44-50psi on the rear. My bike is a 1998 Dyna WideGlide
i run a shinko 120/70/21 front i run 38 cold psi in it
when she heats up in them hot days or when you really carving corners she bumps up to about 40, 41
putbin what is marked on the frame & in the Manuel.
