Ring and pinion replacement
Old May 31, 2021 | 09:06 PM
raysr11's Avatar
raysr11
Stage II
Default Ring and pinion replacement
'97 Fat boy broke the ring and pinion. I'm trying to find a kit that I can use my OEM large coupler. I don't want to remove the starter(again). I see Compu-Fire kits with the ring gear and pinion and Evolution kits with the same. Evolution said I need to use their jackshaft assbly but it has the smaller coupler for the starter and as I said I don't want to remove the starter again. Which of these kits will work with my original jackshaft and large coupler(10 T)? I'm wanting to go 10/84 as I recently installed an engine with 10 to 1 and the starter clutch immediately went then the gears in succession.
Thanks
Old May 31, 2021 | 09:59 PM
Dano523's Avatar
Dano523
https://www.hdforums.com/forum/engin...-releases.html
Old Jun 1, 2021 | 11:01 AM
raysr11's Avatar
raysr11
Stage II
Right. But right now I'm trying to find out what ring and pinion kit I can use with my OEM jackshaft. I cannot find out anything on it.
Old Jun 1, 2021 | 10:15 PM
1997bagger's Avatar
1997bagger
http://images.rolliesspeedshop.com/pdf/CF-54002.pdf
Remove the long pinion bolt to remove the old pinion, install new pinion, put the bolt back in. If you decide to pull the coupler out make sure you note the offset of the c-clip, the back side of the coupler slides over the starter output shaft, starter doesn't need pulled to do this. I have the same ring gear set
Old Jun 2, 2021 | 08:56 AM
98hotrodfatboy's Avatar
98hotrodfatboy
Exactly...
Captnjoe
Dec 28, 2021 07:32 PM
Fxstcustom
EVO
13
Dec 3, 2020 03:22 PM
89FL
EVO
Mar 12, 2018 05:04 PM
Inkydoggy
Ironhead
Apr 4, 2014 01:45 PM
masksqueeze
Oct 17, 2008 08:56 AM
