Oops
Old Aug 23, 2021 | 12:30 PM
  #121
0maha's Avatar
0maha
Originally Posted by Schex
I always seal them with a thick enough bead around the shank right below the head of the bolts and never had a leak, it's pretty obvious those bolts are a potential leak.
Just found out my clutch pack order was cancelled because "technical problem", so I have to re-order.
That gives me some time.
I think I'll go ahead and do this, since I'm on stand-by for now.
Old Aug 23, 2021 | 12:55 PM
  #122
Schex's Avatar
Schex
Energy One is another option, extra plate pack BTX-11 or BTX-11 SP(with Spring)
Old Aug 23, 2021 | 03:39 PM
  #123
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
Omaha, check the bolt holes, are they blind?
Old Aug 31, 2021 | 07:21 AM
  #124
0maha's Avatar
0maha
Good question. Anyone know?
My guess is they go through the cases. But that's just a guess.
Good grief this has drug on! Too many other things going on this summer!
Clutch parts came in last week. Got that installed. Went to put in the primary chain, and my torque wrench felt wrong. Felt like both the clutch and comp nuts were under torqued.
So the next day I took it to a tool shop. Tested fine. I'm to the point of seeing monsters under my bed, it seems.
Another day lost.
Went to install that plate on the clutch that holds the adjuster bolt. Snap ring didn't look good. Looked sprung. Installed it anyway. No good. Didn't come close to filling the slot.
So off to Harley for a new one. $13.53 for that. Damn. Even the parts guy was embarrassed.
Another day lost.
Got it buttoned up the rest of the way last night. Went to start it. Click Battery is dead. Or at least weak enough it won't turn it over.
Dug out my fancy pants tender for my fancy pants battery. Left it on overnight.
This morning it's flashing red. Says the battery is a gonner.
So now I've got an old (conventional) battery on a charger. It won't fit in the bike, but I can use it to verify that the battery really is the problem.
Hopefully, that's it.
We'll see.
In another day.
Old Aug 31, 2021 | 07:38 AM
  #125
strych9's Avatar
strych9
The saga continues
As for the torque wrench feel...maybe you're stronger than you think.
Old Aug 31, 2021 | 08:11 AM
  #126
t150vej's Avatar
t150vej
My guess is they go through the cases. But that's just a guess..
Can't speak to later transmission cases but on your '90 Touring, all the internal inner primary bolts thread into blind holes, engine and trans.
Old Sep 13, 2021 | 07:44 PM
  #127
0maha's Avatar
0maha
Time to put a bow on this one.
FINALLY back together. New battery arrived today. The Antigravity guys were good to me. Mine was about a month away from being out of (prorated) warranty, and they let me swap it out at a very deep discount.
Found out the hard way that I'd over tightened the pinion shaft bolt. That was a bit of a head scratcher. After a half dozen tries reinstalling the outer primary, I decided to RTFM. It was right there: Reinstall pinion bolt and torque to 3 to 6 ft lbs. That got it.
This bike had never had a sumping problem. Until now. Holy *********. First start it unloaded a good quart+ onto the floor. What a mess.
Gave her a quick 20 mile shakedown run. The new belt pulley ratio is wonderful. Sits right at 3200 RPM at 75 MPH. Shouldn't have waited until the old one broke before making that change.
The new clutch is total butter. Smooth.
Thanks to the Evo crew here for all the advice and ideas along the way. This group is the best!
jerryleejr
2018+ Softail Models
15
Nov 17, 2020 04:13 AM
CaptKirk
May 1, 2018 08:21 AM
rockhousebadboy
EVO
15
Jun 25, 2016 09:35 AM
jdw999
EVO
Jul 11, 2014 09:22 AM
dhamilton20
Jul 2, 2010 05:21 AM
