Oops
Old Aug 18, 2021 | 06:07 PM
  #111
t150vej's Avatar
t150vej
Originally Posted by 0maha
When I called my local HD dealer, he was less than helpful. Told me what I really needed to do was come trade in on a new model. I asked him why would I want one of your oil-sumping computer glides?......
with disposable flywheels...? No thanks!
Old Aug 22, 2021 | 09:44 AM
  #112
0maha's Avatar
0maha
Got a question.
I want to get everything buttoned up today so I'm ready for when the clutch arrives next week.
In another thread, Schex posted a pic from a service manual that said you needed to put same RTV on the back side of the inner where the "wet" bolts that hold it on go througj.
My FSM doesn't talk about that, and there wasn't any on the inner when I took it off.
I installed the inner before I saw that post from Schex.
So the question is do I pull it off now and reinstall with some RTV while I can, or just leave it? I'm inclined to go with the RTV unless someone has a reason that's a bad idea.
Old Aug 22, 2021 | 10:22 AM
  #113
t150vej's Avatar
t150vej
I've done them with and without (in the early days), never had a problem (leak) either way. However if you decide to totally un-bolt it and do RTV on the backside, change the big o-ring on the engine, yes again. Unlike most applications, no matter how good they look, once they have been disturbed they're subject to leak. part# 11147B about 3 bucks.
Second option - unscrew them one at a time and "feed" RTV on the shoulder as you push them back in till the the threads start. Torque and let them totally dry and pick off the excess from around the lock plates.
Old Aug 22, 2021 | 10:29 AM
  #114
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
I would leave it alone, the book doesn`t call for RTV, this is something that came later on, not sure when.
Old Aug 22, 2021 | 10:47 AM
  #115
t150vej's Avatar
t150vej
I would call that the 3rd and probably the best option...
Old Aug 22, 2021 | 10:59 AM
  #116
86glider's Avatar
86glider
I’ve done mine dry many times.Always dry,without a leak.
Old Aug 22, 2021 | 12:25 PM
  #117
0maha's Avatar
0maha
Thank you, gentlemen. Appreciate the input.
Guess I'll leave it as is.
If nothing else, my natural laziness likes that answer.
Old Aug 22, 2021 | 12:52 PM
  #118
Yankee Dog's Avatar
Yankee Dog
OK, I'm going to be the "nay" sayer... and I hope all you guys are 100% correct and I am 100% wrong (or unnecessary overkill) ...
I would have put some silicone sealer in the areas circled. It looks like some sealer was there before based on Omaha's earlier pics (or is the black stuff grime?) I can see some residue black silicone sealer (or grime) on the female threads and even see some on the top right (rear most upper female bolt hole just above the belt).
I admit I am not familiar with your model, and my bike is a later model where the manual calls for sealant on those areas. It was there from the factory my fist time in the primary. I am not a fan of this either but perhaps a compromise would be to remove each "wet" bolt (the ones with the locking tabs) one at a time, clean the bolt, tab and inner primary area with brake clean, and apply sealer to the underside of each bolt head and locking tab.
I would hate to have you go thru all the recent work only to have to go in again.
Old Aug 22, 2021 | 03:13 PM
  #119
Don R's Avatar
Don R
Omaha,
my 85 flhtc has a crack on the seal seat of the engine case. I use a case saver gasket to stop it from leaking. The gasket seems to work better than the RTV.
Old Aug 22, 2021 | 09:24 PM
  #120
Schex's Avatar
Schex
I always seal them with a thick enough bead around the shank right below the head of the bolts and never had a leak, it's pretty obvious those bolts are a potential leak.
