‘99 Fatboy rear wheel turns in neutral
Old Sep 14, 2021 | 04:35 AM
GOGOBECK's Avatar
GOGOBECK
Default ‘99 Fatboy rear wheel turns in neutral
On the stand both wheels off the ground, idling, the rear wheel turns slowly.
I also notice shifting from 1st to 2nd gear requires more force than normal, but only the first time through the gears… after she’s warmed up a bit, it clicks into gear easily. Running Bel Ray 85-140 in the transmission.
Would adjusting the clutch help?
Old Sep 14, 2021 | 04:55 AM
eighteight's Avatar
eighteight
[QUOTE=GOGOBECK;20179188]On the stand both wheels off the ground, idling, the rear wheel turns slowly./QUOTE]
Absolutely , positively normal.
Old Sep 14, 2021 | 04:57 AM
Jackie Paper's Avatar
Jackie Paper
Adjust the clutch correctly. If it still does it, it's fluid dragging. Harley's need a little drag to shift correctly but just oil drag. And nothing works better than Formula + in both gear boxes.
My guess is if you compare it with you oil, yours is thicker.
Old Sep 14, 2021 | 05:01 AM
PeterB's Avatar
PeterB
+1 on Formula Plus for Harley transmissions. Seems thinner/lighter than some heavy gear oils, which is good for Harley boxes that use needle rollers in places. Stuff smells like they make it out of fish oil or something...
Old Sep 14, 2021 | 05:02 AM
Stiggy's Avatar
Stiggy
Thick oil, nothing more.
Old Sep 14, 2021 | 05:21 AM
GOGOBECK's Avatar
GOGOBECK
Thanks to all you early risers for the quick responses!
I figured it was just fluid drag, but I’ve never had a bike do this.
Old Sep 14, 2021 | 05:32 AM
eighteight's Avatar
eighteight
I`ve never had a bike that didn`t
Old Sep 14, 2021 | 08:14 AM
Jackie Paper
Both of mine do it. Good wheel bearings. My front came off a Softail with 100K and I have put another 30K on them.
joeperles
Jul 14, 2020 09:10 AM
paco12
Feb 18, 2018 05:05 AM
WKT
Jan 15, 2018 02:02 PM
SecondGear
2014-2024 Touring Models
Apr 8, 2015 07:22 AM
Shakeydeal
Feb 10, 2009 02:15 PM
