What Tuners are Available?
https://www.denniskirk.com/dynojet/p...rd/2009450.sku
Did you add pipes and air filter just now?
Power commander is one option and another is a Cobra Fuel management system.
The power commander is adjusted with a computer while the Cobra is adjusted with 3 screws (pots)
The link below is mentioned by many in the past for a power commander
https://www.fuelmotousa.com/
The link below is for the Cobra unit at J & P cycle
https://www.jpcycles.com/product/zz3...yABEgKG2PD_BwE
https://www.dobeckperformance.com/vi...?vehicleid=485
Here is a used 1040st on ebay right now, and the same unit being sold under revtech,
https://www.ebay.com/p/1976244667
Pros and cons, very easy to tune with nothing more than small screw driver on your own.
https://www.tficontrollers.com/instr.../950141040.pdf
The down side, is that tuner adjusts/ add on fuel to both the warm up and hot fuel curves as one, so you end up running on the way rich side until the motor warms up/where you set the tune to in the end. So a lot of warm up riding is really going to kill gas mileage, over just the way you may have it set for once the motor is warmed up isntead. Without tuner I get over 150 miles on 5 gallons, while with tuner as rich as I run the bike to pull like a freight train, average about 25 mpg installed.
Note, DeBeck has tuners that you can wire into the wires directly, instead of the quick connects at the injectors install isntead. With it, can be the best of both worlds, since can leave the unit off if you need the higher gas mileage with it power connected to the acc switch to turn it off, and with it on, get your power gains isntead.
On the units with the injector intercept connectors, unit has to run full time instead.
As for tuner that you can adjust both the warm up and hot tables with laptop, would just go find a S&S VFI ecm replacement.
It not only comes with it own protune II software, but allows you to use a standard laptop to monitor the motor as well.
https://www.sscycle.com/racing/support
The glitch, S&S no longer offers the VFI for the MM systems, so either have to find a Harley dealer that may still have one since it was used by them for OEM replacements, or find one used that someone does not want an arm and leg for instead (sold for $499 new).
Find the appropriate SE performance cartridges on EBay. These actually reflash the ECM and eliminates any piggy back wiring.
The cartridges are getting more rare as Harley made them obsolete in 2006. But .they do show up.
Unfortunately, then you need to find someone with a scanalyzer or an OTC4000 with the Wiring adapter.
