Blew my engine yesterday
Old Sep 19, 2021 | 09:58 AM
  #81
RhynoRocK's Avatar
RhynoRocK
Originally Posted by Schex
Repeated detonation can do that, the oil getting into the combustion chamber can make it want to detonate more.
Hrmmm, now I'm wondering if I needed to use octane booster and had no idea. The indie dealership I got this from in 2019 couldn't tell me anything about it. I used 90 octane non-ethanol in this bike. The new Ultima requires 92 octane minimum (10.2:1 comp ratio) so I'm adding Lucas octane booster.
Old Sep 19, 2021 | 10:49 AM
  #82
Schex's Avatar
Schex
I don't worry about the ethanol in the gas, I go for the highest octane, 93 around here.
Not that it matters at this point, but it looks like that motor had oil control problems, I can't tell from the pictures, but if those Wiseco's happened to have the 2mm oil rings, there was known issue with oil control, Wiseco changed to a 3mm oil ring set up a while back.
Old Sep 19, 2021 | 02:58 PM
  #83
WP50's Avatar
WP50
Ouch It sure would appear that something got in there with that kinda damage.
Finding that piece in the front cyl just adds to the conversation__ it can happen, not often but have seen it before
WP
Old Sep 19, 2021 | 10:56 PM
  #84
RhynoRocK's Avatar
RhynoRocK
I made the mistake of running some 93 octane E-10 ONCE, misfires & sputtering all the way home from that short trip.
Also, there's a lot of schmutz on the back (manifold side) of both intake valves, big chunks of soot & filth, burnt oil residue. But I'm not seeing a bent valve like I thought, they're all seated just fine.
It's apparent that with that nasty ding in the combustion chamber the heads are history. And upon closer inspection of the crankcase, it looks like someone took a grinder to where the primary mates to it, one of the stator plug retainer screws is snapped off in the threads, and the case leaks a lot. The cam has some small chips in one of the lobes.
I think this motor is now a coffee table stand.
Old Sep 19, 2021 | 11:57 PM
  #85
Tommy C's Avatar
Tommy C
A good welder can fill in the dings in the combustion chamber with a tig welder.
Old Sep 21, 2021 | 05:55 PM
  #86
RhynoRocK's Avatar
RhynoRocK
I've been asking around my locale, nobody seems to know anyone willing/able to do that. Probably send the heads out to get worked on in the future. Or buy some aftermarket ones. We'll see.
Old Sep 21, 2021 | 07:53 PM
  #87
Tommy C's Avatar
Tommy C
Someone welded up those heads to get the bath tub combustion chamber.They could be Branch Heads. Jerry favored that configuration.
hattitude
Nov 15, 2019 11:53 AM
jsbridgew
EVO
Sep 7, 2013 06:58 PM
trnewman
May 11, 2013 04:30 PM
Jefferson
Exhaust System Topics
Nov 20, 2009 07:19 PM
Moonor
The General Motorcycle Forum
60
Oct 29, 2009 12:17 AM
