Turn signal - only lit when flashing
Old Jul 21, 2021 | 08:53 PM
Windseeker's Avatar
Windseeker
Default Turn signal - only lit when flashing
As the title says... I RARELY ride after dark. Well, tonight I was out for a bit after sundown. When I went to ride home, my left signal bulb was lit and the right one wasn't, unless I turned on the right turn signal.
So in short:
Left side is lit, right side is not, with headlights on. Left turn signal functions normally.
Right side flashes when right turn signal is on, otherwise dark.
Ideas?
Old Jul 21, 2021 | 09:14 PM
IronAss's Avatar
IronAss
You have a filament burned out in your right bulb. Replace it.
Old Jul 21, 2021 | 09:15 PM
Windseeker's Avatar
Windseeker
That's what I was thinking, but I wasn't sure which one.
Thanks!
Old Jul 21, 2021 | 09:21 PM
im's Avatar
im
So in short:
Ideas?
Taking a guess this is on the Fatboy.
Taking another guess you are referring to front turn signals.
From factory the front turn signals are an 1157 bulb.
The 1157 bulb has TWO filaments.
One filament is ON always when bike is ON.
The other filament is OFF unless blinkers are in use (used to flash only).
I would change both sides since bulbs often are sold in pairs at auto parts shops and the other bulb could go soon.
Old Jul 22, 2021 | 08:55 AM
Windseeker's Avatar
Windseeker
Thanks for the info. I just called the local Harley parts department, and their price is $12.00+ for a pair.
But instead, I'm going to go to Walmart, which is a few miles closer, and get a pair for $4.25.
Old Jul 22, 2021 | 09:46 AM
Windseeker's Avatar
Windseeker
New change of plans: I just ordered low-power LED 1157 replacements from Amazon and they're supposed to be here tomorrow. These are rated at 300% brighter than OEM. If I like them, I'll order another set for the rear.
Old Jul 22, 2021 | 10:08 AM
mike131's Avatar
mike131
LEDs may not work with out a resistor, not enough resistance in a led to flash or will flash fast
Old Jul 22, 2021 | 10:11 AM
mike131's Avatar
mike131
I think they do make some leds bulbs with resistors built in?? but I usually have to install a resistor and alot of leds I find are too large to fit under the lens
Old Jul 22, 2021 | 10:14 AM
eighteight's Avatar
eighteight
[QUOTE=mike131;20069040]I think they do make some leds bulbs with resistors built in?? /QUOTE]
Have a make & model for these ?
I`ve been unable to source them ..
Old Jul 22, 2021 | 10:16 AM
WP50's Avatar
WP50
The LEDs usually cause a turn sig to hyper flash on older bikes.
The flasher isn't going to like the low resistance of an LED bulb.
There's ways to fix it by adding a resistor to the circuits.
WP
