Marelli fuel injection
Old Oct 6, 2021 | 05:15 PM
Travis72's Avatar
Travis72
Stage II
Default Marelli fuel injection
Please help. I have a 97 ultra classic that has been giving me fits with idle issues. Occasionally it will ramp up to over 3000 and you can't get it to stop. Or it won't take any throttle, idles fine but falls flat when you crank the throttle. I've tried the resets of turning it off and on 3 times and unplugging the fuel pump and ecm fuses for a half hour or more. And the other day I tried the tps reset by adjusting it's position to .275 v and then running the cold idle set screw in til it's at .650 v. That worked for one day of long riding and then the next day it was back to loading up, not taking the gas, and ramping the idle back into the 3000 range. Seems like everything I try fixes it for a minute and then it returns. What gives here? Anyone have a definite fix?
Old Oct 6, 2021 | 06:36 PM
mike131's Avatar
mike131
I'm not an expert on marelli injecton, I am on auto, to me it sounds like a faulty tps, throttle position sensor
Old Oct 6, 2021 | 06:44 PM
mike131's Avatar
mike131
And a faulty temp sensor will mess with them also
Old Oct 6, 2021 | 07:22 PM
mike131's Avatar
mike131
On auto's I'll test the tps by reading the voltage while i open and close the throttle making sure the voltage change is smooth and not jumping around, if jumping tps is faulty
Old Oct 6, 2021 | 08:06 PM
Dr.Hess's Avatar
Dr.Hess
Those systems are known for having the temp sensors go bad on you on a regular basis.
Old Oct 7, 2021 | 10:05 AM
larsfum's Avatar
larsfum
Two things come to mind. The first is what Dr. Hess mentioned. The second is a faulty Idle Speed Control Motor. After you unplugged the ECM and Fuel Pump fuses did you do the On Off thing again to synch the ECM to the ISC?
Old Oct 7, 2021 | 04:16 PM
carlgrover's Avatar
carlgrover
Check to see what codes you have stored in the system. If you get a code 14, you'll need to replace the engine temp sensor. The symptoms sound pretty much how they do when they're bad.
carl
Old Oct 8, 2021 | 07:23 AM
RLH3175's Avatar
RLH3175
Watch this video, it was what I used to tune my 1996 Ultra Classic....
Old Oct 8, 2021 | 08:14 AM
kantdo55's Avatar
kantdo55
My 2000 Ultra Classic had the same problem described when it was less than a year old. Replaced the idle speed control motor. Problem solved.
Old Oct 8, 2021 | 08:18 AM
im's Avatar
im
You have a 1997 Ultra Classic (a touring EVO powered bike)
It has unknown miles and we do not know if there are any changes from stock.
Unknown history of ownership or when the bike last operated correctly.
You report:
Idle issues. Occasionally it will ramp up to over 3000 and you can't get it to stop. Or it won't take any throttle, idles fine but falls flat when you crank the throttle.
You attempted computer reset.
From a distance and based on information provided.. it reads like engine temperature sensor.
A bad engine temperature sensor will cause bike to flip/flop incorrect temperature reading and bike will think it is ice cold and then immediately think it is very hot.
A run away idle would be a strong indicator that temp sensor is bad.
