Dad's 87 FLST
So, to explain why I did that mount before the head bolt mounts was so I could be sure the two lower connections on the head were free floating so to speak.
Why did I align the rear wheel. well apart from the things I mentioned above already was the fact that this bike was 30+ years old with an aftermarket engine. (S&S) and God only know how many people have had their hands on it before, and was the frame even straight?
I know the trans plate wasn't, it didn't sit flat on a glass plate, it was chrome, I had that striped, I straitened the plate in the press, got it powder coated and then sanded it on the glass plate till it sat flat. I also a had striped receivers on the rear where the trans plate bolted to the frame and had to drill tap and put nut certs in. pretty sure those both or at least one of them had the wrong thread type bolt in it.
Now again why the Wheel alignment? I didn't want to get the motor, trans and inner primary all pulled together and tight to the frame to find out that the front pully was cocked slightly to the left or right. additionally, prior to pull down my belt tracked to one side of the rear pulley (aftermarket). it could have been the spacing on the pulley to hub, but I didn't know this either. As part of this rebuild, I refitted the original rear pulley that I had customized (see image below). So it just made sense to me to start on the back wheel and get that square to the swingarm in the position that it would live in when reassembled and running down the road. What interested me in the original posters post was his motor is or was (old dyno sheet) about the same HP as mine and from what I had read and was fearful of was what has happened to him, might have happened to me.
I totally agree with the loose bolts, I just thought that was a given but undeniably it was the torque twist allowed by the loose bolts that broke the inner IMHO.
As I said earlier this bike leaked a lot of oil and I have posted on those fixes in my previous posts, oil tank, trans main shaft and quad seal, outer primary seal/gasket. This bike is currently sitting in my lounge room and does not leak a drop. I ride it and get on it.
All are my fairly recent practical experiences, did I do exactly what the manual says, no I didn't, I replaced course thread with fine and torqued things higher than factory spec. Did I do anything that would compromise the integrity of the build? i don't think so. in my opinion and that's pretty much all i have is that i went over and above.
sorry for the long post.
Good rotor last fall
Bad rotor last weekend
As for the starter I would get an upgraded 1.2-1.4kw starter.. Believe All ***** had em..
Wheels = Crankshaft Flywheels.
