Ev27 cam replacement trouble
Old Dec 28, 2021 | 07:55 AM
norml's Avatar
norml
Rright on.thks for the replies.A bit of assurance is a good thing.
Old Dec 28, 2021 | 10:37 AM
0maha's Avatar
0maha
I think if you're confident you have the bearing correctly seated, and you've inspected the cam and can verify that the gear is seated on the shoulder, and you can bump the cam back and forth with the cover bolted on (ie, it's not binding up), you're probably good to go.
It's almost certainly not a problem, but double check that the inner most cam lobe is clear of the case through it's full rotation.
Old Dec 28, 2021 | 12:55 PM
norml's Avatar
norml
Thks . I'll verify the above before installing the cover.
Old Dec 28, 2021 | 03:17 PM
Yankee Dog's Avatar
Yankee Dog
It's always good to rotate the engine (at least one complete revolution) by hand to check for any unforeseen problems, BEFORE starting for the first time after any internal engine work.
Not sure if it was mentioned, but often forgot (or lost during disassembly), did you reinstall the little nylon spacer for the breather gear? It goes between the plastic breather and the cam cover. The reason I ask, is they can get stuck on the cam cover during disassembly and never noticed. It looks like a little off white nylon washer about an inch in diameter. Just a heads up.
Old Dec 28, 2021 | 03:39 PM
norml's Avatar
norml
Yes i have the breather spacer.The engine rotates freely with no binding anywhere.I guess im good.Im new to the forum. Lots of good info here. Cheers
Jasper86
EVO
13
Dec 9, 2020 04:15 PM
notop71
Mar 6, 2020 03:57 PM
0734
Engine Mechanical Topics
Jul 3, 2014 06:38 AM
Lumpy46
EVO
13
Dec 24, 2012 01:16 PM
73HDFX
Shovelhead
Jul 1, 2011 11:59 AM
