96 Roadking engine temperature sensor question.
Old Jan 1, 2022 | 03:35 PM
norml's Avatar
norml
Default 96 Roadking engine temperature sensor question.
I did a M/M efi to carb conversion a couple years back with no regrets.This winter I'm doing a cam, cam bearing,lifters,boring the cylinders with new pistons and rings and cleaning up the heads.I have a question about the engine temperature sensor in the front head no longer being used.I was thinking of removing it and just installing a bolt and washer and maybe red locktite.Any thoughts?
Old Jan 1, 2022 | 06:37 PM
carlgrover's Avatar
carlgrover
Just remove the sensor and let it go. No need for a bolt. If you do want to put a bolt in there, DON"T use red locktite. Absolutely no need.
carl
Old Jan 1, 2022 | 08:16 PM
1997bagger's Avatar
1997bagger
carl
Follow Carls advice, the sensor hole isn't open to and ports, been there done that.
Old Jan 1, 2022 | 08:35 PM
norml's Avatar
norml
Ok thks.I didn't realize it was just an empty threaded hole that goes nowhere.
eighteight
Jan 3, 2020 09:51 AM
Fullcircle
Mar 28, 2019 09:38 PM
balesarich
May 29, 2017 08:47 PM
jdreed520
Jun 4, 2010 09:58 PM
HDF Tech
Sep 23, 2005 12:02 PM
