I think it's machine time
Old Feb 5, 2022 | 03:42 PM
Mountainkowboy's Avatar
Mountainkowboy
What do your pistons measure 1 " from the bottom oil ring on the skirts and are they cast or forged?
I believe it was 3.587. I can't work on her anyhow, the "community" site inspections are next week, so my shed is stuffed full of items that are none of their business. One of the MANY reasons we bought in Idaho..
Originally Posted by carlgrover
How close is your repeatability with calipers? Do you get closer than 1/2 a thousandth measurement to measurement?
carl
Hence why I measured them so many times.
Originally Posted by Dehammer
I am a machinist. ID measurement with calipers is not applicable for the clearances you are trying to realize. Even a premium quality Mitutoyo caliper has limits. Telescoping bore gauges are problematic as well, even so they should be measured by a micrometer after a gauge block qualification. I do not work with cylinders but I would guess without a torque plate you would get irrelevant readings anyway.
A shop that specializes in doing this work should have the proper bore measuring tool and/or CMM to get you set up right.
Seeing how it had piston slap on cold startups, smoked, and with the scaring that's showing on the piston skits, it tells me that the piston to bore clearances were most likely far out of spec to start with. I was just curious as to how far out that they might be. I will order an overside piston kit and take the lot to a machine shop and have the barrels machined to match the new pistons.
Old Feb 5, 2022 | 07:08 PM
Dehammer's Avatar
Dehammer
Exactly what I would do.
Old Feb 6, 2022 | 07:35 AM
98hotrodfatboy's Avatar
98hotrodfatboy
Sounds like you measured the top of the piston.. A 3 5/8" Forged piston should measure 3.620" at the skirt allowing for .0025- .004" fit with .004" being on the loose side..
Old Feb 8, 2022 | 10:05 PM
00 fxd's Avatar
00 fxd
I need to ask, do we not need to know whether the pistons are cast, hypereutectic cast [Kieth Blacks] or forged?
nathanw
Engine Mechanical Topics
13
Sep 8, 2014 07:56 PM
roussfam
Exhaust System Topics
24
Jan 13, 2011 02:22 PM
spankustang
Mar 3, 2008 10:29 AM
gatorwalt
Feb 28, 2008 11:29 AM
ChrisB
Ironhead
Sep 12, 2007 05:16 PM
