Oil Pan Drain Plug
Old Feb 9, 2022 | 12:52 PM
saintslax11's Avatar
saintslax11
Default Oil Pan Drain Plug
Hey fellas...
When I owned my 06 Night Train, I replaced the o-ring every time I did the oil. With that said, does my 85 FLTC have/need any type of o-ring/crush washer for the drain plug? Or is it just torqued to a certain ft lb/Nm?
Thanks in advance. A lot of learning on this thing as I go. This is about the only question I have not been able to find on Google.
Old Feb 9, 2022 | 01:24 PM
t150vej's Avatar
t150vej
Originally Posted by saintslax11
Hey fellas...
That oil drain plug is a 1/2-20 thread that uses a 6113 washer. It's very thin metal.
My '87 has a sender (brass, same thread) for the oil temperature gauge. I didn't use any washer for nearly 30 years with zero leaks.
If yours has a metal drain plug, you might find that washer at a dealer, it's not discontinued. Plugs are n/a but most any auto parts store carries them. (1/2-20 thread) If you choose to use OEM washer or simply a 1/2 copper washer, torque it 18-20ft/lb. They are not bad to leak or come loose.
Old Feb 9, 2022 | 02:12 PM
86glider's Avatar
86glider
I’ve changed the oil in my ‘86,never a leak reinstalling the brass sender plug.
Old Feb 10, 2022 | 12:12 PM
saintslax11
Thanks guys. This is def a work in progress.
I really need to start a thread on this build.
Old Feb 10, 2022 | 04:28 PM
mike131's Avatar
mike131
On mine every once and awhile I'll throw on a new copper washer, I know its probably not correct but works
reid.cuppett@gmail.com
Mar 15, 2017 12:37 PM
PhatBoyHigh
Nov 25, 2015 11:11 AM
aces&8s
EVO
11
Sep 8, 2013 09:43 AM
jamala00
Mar 24, 2012 03:10 PM
harleydom55
Oil Archive (no new posts)
Aug 11, 2008 05:09 PM
