No rear cylinder fire
Old Feb 20, 2022 | 01:33 PM
t150vej's Avatar
t150vej
Despite my rant about intake leaks (which I stand by, generally speaking) since it's totally dead on the rear, I'm leaning toward a failed ignition module now.
Without getting into the weeds too far my logic is this - possible one of the pickups has given up and though it's firing on both plugs, could be it's only firing at the correct time for the front and what shows as the rear plug firing is actually the wasted spark for the front. Meaning, it's not firing at the correct time for the rear and the front isn't getting a wasted spark. The "wasted" spark for the front is the compression spark for the rear and vise-versa with a dual fire coil.
This is the nose cone version, right? What setting is the "Mode" switch" on? Did you install it or was it already on there when you got it? (I'm trying to come up with an easy "check" that might verify my guess on the module half dead)
Old Feb 20, 2022 | 02:31 PM
Schex's Avatar
Schex
You can test spark strength with a screwdriver, insert screwdriver in plug boot, hold plastic handle of coarse, then hold screwdriver shaft about 1/4" away from a cooling fin and crank engine, adjust gap to see how wide of a gap it'll jump, compare to other cylinders plug lead. **ground the other plug lead, or put the plug in it and lay it on the head, not good on the ignition module to fire with no resistance on the lead**
it takes a lot less voltage to fire a plug in open air than it does under compression.
Being it has a brand new DTT module I doubt it's bad, but maybe some sort of timing issue, I would make sure the timing cup for the cam sensor didn't come loose or something, or a mode coil issue, That link I post in post #11 talks about what ohm coil to use, if it was mine, I would get a single fire coil and go single fire for sure.
I remember reading something long ago about two different timing cups on certain years when replacing ignitions? I not sure if that's even relevant here.
Old Feb 20, 2022 | 02:55 PM
t150vej's Avatar
t150vej
One more thing I missed multiple times, "new DTT" ...
A plug will fire in open air much easier much easier than under pressure. These modern ignition should throw a bright white/blue spark at least a 1/4"
Good suggestion checking the cup and mode setting. Should be on 0,1,4 or 5 with the pink wire to the stock type coil.
The later Shovels used a single window cup that were silver (zinc) and they changed to a 2 window cup that is gold (yellow zinc) in mid - '83 and up.
Old Feb 20, 2022 | 03:21 PM
NavyChief79's Avatar
NavyChief79
6th Gear
Modes switches are definitely correct and the cup is brand new as well as front fires no problem so the signal is getting to the module correctly. Just opened the pushrod tubes and it does have screaming eagle adjustable pushrods. They are tight and the jam nuts are set. I have bike on a jack and will go through the adjustment process to ensure they are correctly adjusted. Hoping this is the issue.
Old Feb 20, 2022 | 03:56 PM
Yankee Dog's Avatar
Yankee Dog
Delete
Old Feb 20, 2022 | 07:53 PM
98hotrodfatboy's Avatar
98hotrodfatboy
Pull the timing plug on the left side of the case and Bring your front cylinder up to TDC. . Then take the cover of the ignition in the nose cone as well as the ignition module.. take a picture of the rotor cup and post it up.. The front cylinder must be at TDC for this..
Old Feb 20, 2022 | 08:14 PM
RANGER73's Avatar
RANGER73
Thought you said it was stock? Now I read mode switches?
So, new electronic ignition, new coil.
is the coil single fire or dual fire? And is the ignition programmed accordingly?
Old Feb 20, 2022 | 08:49 PM
1997bagger's Avatar
1997bagger
2 different rotor cups available, carb and efi, they will not interchange, not saying that's your problem but this one is strange.
You have a wet rear plug on dual fire, crossing plug wires doesn't make a difference, it won't fire, compression is good. Since this is such a strange one, if you can't find anything wrong with it, make sure a mouse didn't build a nest in the rear muffler, the cylinder will not fire if it cannot get spent gases out, just a back up plan.
Old Feb 21, 2022 | 01:37 PM
Schex's Avatar
Schex
You can loosen the both pushrods on one cylinder, then take the schrader valve out the end of your compression tester hose and use it to put compressed air in that cylinder, listen at exhaust pipe and intake for valve leaks, and if the blow by sounds excessive out the breather, that part is just guessing, but you can compare it to the other cylinder.
Old Feb 22, 2022 | 05:56 AM
NavyChief79
6th Gear
unfortunately I won’t have a chance to work on this again until Friday late day at the earliest. Also going out of town Saturday and Sunday so may be the following weekend before I really do much more.
Anthony Elsmere
Feb 21, 2022 08:15 AM
D-Bag
Engine Mechanical Topics
Jul 17, 2014 09:21 AM
stellar
Aug 24, 2012 12:21 PM
n.texan
Ironhead
Jun 21, 2011 09:33 PM
Mongo43
EVO
May 3, 2008 08:42 AM
