FXD dreams
Old Jul 23, 2022 | 03:35 PM
  #41
Trumpet's Avatar
Trumpet
Originally Posted by Stiggy
The trim ring on my '02 Low Rider doesn't quite close up all the way either after I installed the LED bulb. (but its gppd enough for the guy that owns it )
Glad to see it is not just my issue. Still will play with it again.
Old Jul 23, 2022 | 03:40 PM
  #42
Stiggy's Avatar
Stiggy
"Mine doesn't have an internal mount like yours seems to have though. The LED's are simply larger because those cooling fins stick out so much from the back. My outer trim ring holds the bulb in place in the bucket."
(added that to the above post.)
Old Jul 23, 2022 | 04:04 PM
  #43
Trumpet's Avatar
Trumpet
Pretty much the same. The eagle lights is a hair larger than the retaining ring. I cut the ring so it'd all go together. I'd like to think it can be done better than that.
I could try reducing the diameter of the headlight with a grinder/buffer. But do not want to void the warranty.
Going to sleep on it. Probably ignore it altogether, as long as the headlamp doesn't move around. I did use a couple dabs of rtv to set it. So the odds are good its the way it is....for a long time.
Old Jul 24, 2022 | 01:40 PM
  #44
Trumpet's Avatar
Trumpet
Dicking around before steak grilling time. Backrest is pretty shot, so....
I'll live with it a few days then decide if I want to spend any coin..
Old Jul 25, 2022 | 07:58 AM
  #45
Bubba Zanetti's Avatar
Bubba Zanetti
Good thinking. Nice way to save a few bucks.
Old Jul 25, 2022 | 04:51 PM
  #46
Trumpet's Avatar
Trumpet
@Bubba Zanetti , yep, it's growing on me. Need a better stapler though, trip to the Depot is in order.
Got the rear prepped for the new slim turn signals, should just delete them. No one pays attention other the the popo. But why give any additional reasons to get stopped. That got old in the 80's, the four questions and maybe want to see your paperverk.
Got the vintage bags cleaned up as well. Bags had a white coating on them. SOm Lexol cleaned them right up, then hit them with some Danner boot dressing. I'll buff them out tomorrow, I guess.
Just nothing to do but some detail cleaning while waiting on the signals...sigh.
Studs on the bag will go nice with the studs on the seat.....Mustang seat you ****
Old Jul 26, 2022 | 06:13 AM
  #47
Bubba Zanetti
What are you using to space the bags out away from the wheel? I have a set of bags I want to slap on my bike but need to get some ideas on how to keep them form going into the wheel or having the swingarm hit them when going over bumps.
Old Jul 26, 2022 | 07:07 AM
  #48
Trumpet's Avatar
Trumpet
The bags backing are rigid and 'look' like they'll stay clear by themselves. Otherwise I have a pair if saddlebag rails left over from a sporty. I'll adapt those if needed. Might have to do a spaced heat shield on the right bag, it's pretty close to the pipe outlet, and might roast.
Also have a great day idea for a support rail, I'll bend up some copper pipe to see if it'll work. But I'm still waiting on the reg and plates, have road tuning to do that ain't done yet.
Lots of ready made bits available,
https://www.google.com/search?q=Dyna+saddlebag+supports
After looking at the results, maybe I'll trade a hour of billable for a ready made solution.....remains to be seen
Edit: Seems its already made!
Old Jul 26, 2022 | 07:53 AM
  #49
Bubba Zanetti
I've seen those store bought rails, I was thinking of fabbing my own for the Dyna. I did a pair for my Honda using some flat stock steel from the scrap bin at work.
Matter of fact I think I'll pop down there and scrounge through it today and see if theres anything useful.
Old Jul 27, 2022 | 04:30 PM
  #50
Trumpet's Avatar
Trumpet
No pics today, turn signals came in, look nice. But of course the hardware is wrong, need to run to the store and get what fits......but granddaughters here and needs watching.
Guess I'll go tomorrow.
Otherwise its all prepped and ready to go.
