What tool...
Old Aug 18, 2007 | 06:49 PM
cyrilaudet's Avatar
cyrilaudet
6th Gear
Default What tool...
Hi
I own a Dyna 1996, and i cant open this *&?%$/ plug .
The oil screen plug that is . Why H-D did not use an Allen head on this one like many others ??? She is almost strip by now.[:@]
Thanks for your help guys.
Old Aug 18, 2007 | 09:18 PM
im's Avatar
im
Default RE: What tool...
You can pick up a drag link tool from sears. It looks like a large screwdriver and is about the size of a socket. You use it on 1/2 inch drive ratchet and come in different sizes for about $6. Replace it with an acorn nut type after you get it off.
Thumbnail Image
Old Aug 18, 2007 | 09:31 PM
im's Avatar
im
if you type drag link tool in the search tab on the top of page 2 links will come up..one has the picture.. if you can not wait... i have removed it in the past with a small fat flat srewdriver tapped very very lightly sidewides..tightly...then used some channel lock type pliers to grab the screwdiver...others have used a cut down allen wrench sideways...drag link i think would be the best....if it is almost stripped...consider backing-off untill you can get the drag link or similar..because once it is stripped it will become more difficult..
Old Aug 19, 2007 | 06:38 AM
cyrilaudet's Avatar
cyrilaudet
6th Gear
Thanks im for your response.
Cyril Audet from Quebec
Old Aug 20, 2007 | 11:37 AM
ceduby's Avatar
ceduby
Had the same problem1997 Dyna. Used an impact driver and it came loose very easily.
Old Aug 20, 2007 | 10:59 PM
meveratt's Avatar
meveratt
Use an impact driver with the largest flat bit you can. Then buy a new plug and o-ring, and don't overtighten it!
blueridge
Jun 13, 2016 10:47 PM
bluharley
EVO
31
Aug 29, 2013 08:16 AM
AllenW
Mar 13, 2013 08:55 AM
bsljacques
Sep 13, 2011 08:24 AM
paud
Aug 9, 2010 01:07 PM
