1986 compensator spacer
Old Nov 15, 2022 | 10:50 AM
hdpearson13's Avatar
hdpearson13
Default 1986 compensator spacer
Hello need to get size of the compensator’s spacer on a 1986 fxst. Don’t have a Manuel. Are these a wear item possibly. Old friends bike that his Son has now , he works on it when he can. The primary is not lining up he may have the wrong size spacer on now. I’ve seen spacer kits but the belief is it’s all stock. Thanks
Old Nov 15, 2022 | 11:03 AM
Racepres's Avatar
Racepres
Last I knew H-D offered various Thicknesses... No Help...sorry
Old Nov 15, 2022 | 11:48 AM
Dr.Hess's Avatar
Dr.Hess
You have to measure it and order the right size, or get the kit.
Old Nov 15, 2022 | 03:16 PM
98hotrodfatboy's Avatar
98hotrodfatboy
Measure the difference between the front and rear sprockets then measure your current spacer.. An or subtract what ever is necessary to get the sprockets equal.. The spacer usually goes between the rotor and the shaft extension...
Old Nov 15, 2022 | 04:46 PM
johnjzjz's Avatar
johnjzjz
The large washer goes on the out side of the drum and small ones are under the drum - yes they are sizable to use
Old Nov 15, 2022 | 05:45 PM
hdpearson13
Thanks everyone
Old Nov 16, 2022 | 07:48 AM
Racepres's Avatar
Racepres
The Spacers, are trying to reinforce that cheap ***, newer Rotor..at the splines.
Old Nov 16, 2022 | 08:32 AM
johnjzjz's Avatar
johnjzjz
It was expensive to make the dished original drum with weak magnets
Rains2much
Nov 11, 2022 09:18 AM
Activate
Aug 22, 2021 02:50 PM
caoboii
May 27, 2017 12:49 AM
Good_Apollo
Jun 25, 2012 09:17 PM
squidly
Jun 1, 2010 03:31 PM
