strpiped primary thread
Old May 31, 2010 | 01:26 PM
squidly's Avatar
squidly
Default strpiped primary thread
Dose any one know what size helicoil (I need to go the next size up) I need to fix primary case threads? 1985 FXST
Old May 31, 2010 | 01:34 PM
Gliden's Avatar
Gliden
Why don't you try to retap it?
Did you easy out what was in there or drill out the whole thing thread and all?
Old May 31, 2010 | 01:47 PM
lo-rider's Avatar
lo-rider
Default heli-coil
A Helicoil is designed to replace the original screw-thread. Unless you really butchered the removal, select the same-size Helicoil. This allows the original size bolt to be used. There is normally no need to go over-size, unless you screwed it up unnecessarily. Just check the drill size recommended for the correct thread to be sure that it will cleanup.
Old Jun 1, 2010 | 03:31 PM
squidly's Avatar
squidly
The treads were damaged to begin with. They had a helicoil in before and stripped out.
I don't know if the same size helicoil will take hold.
I would like to put the same size in so I can use my chrome bolts.
I will have to drill the old helicoil out, just thought it would go better if I put a little bigger bolt in there to make sure I get a good fit with the new helicoil.
TSD
Dec 28, 2015 04:45 PM
JWD
Mar 28, 2013 11:54 AM
Good_Apollo
Jun 25, 2012 09:17 PM
Jaymac3772
Jul 15, 2010 08:03 AM
Buggz
Apr 21, 2008 07:52 PM
