Springer frontends
Runs fine, really nimble compared to my 07 Ultra,
Was thinking of putting a Springer front-end on it. (has a leaky front tube anyway) I like the way they look.
BUT, I thought I'd ask if I'm making a mistake by doing this. Will I lose the nimbleness and agility?
Regards, And thanks
MG
Fix the fork seal leak, 2 beer job over the winter on a Sunday and enjoy the handling of your FXR. Good luck.
and... What is the VIN (minus the sequence Numbers) on that 1983 with an Evo??? Never even Heard of one Verified!!!
would be 1HD1EA-(or EB, or even EC) L (Not-K) XX D (not E nor beyond) XXXXXXX
Thank You
BTW I really do Like New Springers on Softails...and certainly the Old (mechanical brake) Springers on 4-speed Big Twins!!!!
https://www.lowbrowcustoms.com/blogs...ZIVc%3D.NZv8v3
This VIN decoded 1HD1EBL33EY117635
1 The first digit represents where the bike was made. 1 = USA
HD The following HD represents Harley-Davidson.
1 The fourth digit represents the weight class. 1 = Heavy Weight, 4 = Light Weight, 8 = Sidecar.
EB The next two characters represent the model. (see Model Code Chart below). EB FXRS - FXR Sport
L The 7th digit represents the engine type (see Engine Codes Chart below). L 1340 Evolution
3 The 8th digit represents the introduction date. 1 = Regular, 2 =Mid-year, January, 3 = California Special, 4 = Daytona, March
3 The 9th digit is a check digit. If you dont know what a check digit is, it is simply a digit to make sure the entire string is valid.
E The 10th digit is the year of manufacturer. E 1984
Y The 11th digit is the assembly plant the bike was made in. Y = York, PA, T = Tomahawk, J = Milwaukee, K = Kansas City.
117635 The 12th to 17th digits are the production numbers.
jeff
Have found in books they brought out some evos early and some shovels ran into 84
Jeff
Wanna spend wise money go inverted frontend.
