Speedometer again
Old May 29, 2023 | 11:41 AM
glidein wide's Avatar
glidein wide
Default Speedometer again
Speedometer is working but odometer is stuck while tenths was turning to zero, now I once again have no fuel gauge,new OEM speedo, lasted almost 14k , what can be done, this is forth since I owned it...
1986 wide glide..
Old May 29, 2023 | 11:53 AM
johnjzjz's Avatar
johnjzjz
Road racing we use a GPS speedo very small helps the rider corner speed but the factory uses china for its quality stuff SO
china under sea auto and truck tunnels have major leaks and everyone thinks its OK you get a salt water wash top and bottom and passage for one price
Old May 29, 2023 | 05:07 PM
Dano523's Avatar
Dano523
On speedo, mech unit, so would check the cable/make sure its lubed and check the other end to make sure you don't have a worn out gear in the drive unit.
Short of that, just bad speedo;s that it internals are not holding up instead.
As for fuel sensor/gauge, would give it a once over to find it problem. Hence move the float arm up and down while you check resistance on the senor to make sure it working to begin with.
Worst case, may have to pull apart the gauge to re-solder some of the connectors in it, and even a light bit of lube if the needle part is sticking, not slowly returning to Zero when you such the bike off.
On my fuel level unit in a 97 RK, it uses a ground off one of the shafts for a nuts on the outside that had broken the solder joint in the unit when the bolt was over torqued to twist the nut shaft, and soldering that area back up, resolve the the problem of the gauge not working. Hence gauge working was depend on how tight I had the connector bolts, or if one of the nuts needed to be loosened, so know that it was a connection problem in side the gauge that was the problem at hand.
dixonk
Dec 3, 2022 08:20 AM
97FXDWG808
Jan 19, 2014 05:44 PM
Jamesrobert81
General Topics/Tech Tips
Jul 22, 2013 01:03 PM
zillars
Dec 9, 2009 07:08 PM
whitedaddy
Jul 14, 2007 02:27 AM
