Replacement Voltage Regulator
Old Jun 1, 2023 | 04:33 AM
galtjunk's Avatar
galtjunk
Thank you.
I will run all of these tests this weekend.
Old Jun 1, 2023 | 05:52 AM
PeterB's Avatar
PeterB
Been running a Cycle Electric reg on my 95 RK for years. All good.
Old Jun 1, 2023 | 06:53 PM
Ozzie John's Avatar
Ozzie John
I also run Cycle Electric Regulator and stator, i believe they are a Mosfet Type but CE don't advertise them as such. The stock Harley is a shunt type regulator not as effective "Switch" as a Mosfet as the shunt type generates more heat in the switching process and heat = shorter life.
sounds like your going through more than you should though which as others have said may indicate other issues in the charging system. If you don't want to spend the money on a CE set up, i would still advise using a Mosfet type and there are suppliers out there that specifically advertise Mosfet type regulators for Harley classics.
here's a link https://rmstator.com/en_ww/partfinde...gulator&cat=69
Old Jun 1, 2023 | 08:26 PM
GREENOHAWK69's Avatar
GREENOHAWK69
Originally Posted by Yankee Dog
In addition to what has already been mentioned, comp-u-fire make a nice regulator as well. Been running the same one for years. Voltage at 1000 rpm's has always been in the 14.2 to 14.5 range. Made in USA same as the cycle electric.
https://pertronixbrands.com/products...-oem-74519-88a
I also run the Compu-Fire 3-phase for a number of years.
Old Jun 5, 2023 | 10:15 AM
galtjunk's Avatar
galtjunk
I ran the ground check after replacing the regulator and all is well.
Thanks
eske29
Jul 12, 2023 07:52 PM
jonmerrill
Dec 27, 2015 04:19 PM
FL-kruzen
Mar 28, 2012 06:46 PM
TravelingBiker
Oct 12, 2009 09:41 AM
schlof
Dec 16, 2005 05:35 PM
