Replacement Voltage Regulator
I lost my voltage regulator last weekend.
It was over charging and it ate the battery.
I got towed to a town where I could get a new battery.
The tow was $600.
I'm glad I paid the extra few bucks for towing insurance.
I replaced the battery.
I couldn't get a new regulator.
I disconnected the headlight and the voltage regulator and drove it 120 miles home on just the battery.
This will be the 4th regulator I have replaced since I bought the bike 15 years ago.
Is there a better regulator than the stock one available?
Pricey but worth it IMO.
There's certainly nothing special about the OEM charging systems (low bidder wins.)
Need to thoroughly check the stator also.
Post# 2 - https://www.hdforums.com/forum/engin...85-stator.html
Or - https://www.hdforums.com/forum/evo/8...ng-system.html
But also would upgrade to a three phase system from Cycle Electric since you need to get back into the system.
The two phase systems on the older harley's don't put out much voltage at lower RPM's and if you have added more electrical demand to the system, the stock system is going to be fighting to recharge the battery back up from lower rpms, once you do get enough RPMs to bring the charging voltage back up.
With the three phase system (stator and regulator) not only do you get more over all charging amperage, but higher voltage at lower rpms to keep the battery fully charged there too. Also, on the Cycle Electric voltage regulator, go moffitt voltage regulator, isntead of shunt regulator, since it produces less heat to burn it up in the first place.
https://pertronixbrands.com/products...-oem-74519-88a
Please describe the ground test for me.
Thank you.
Set meter on a low DC Volt setting (not mV) or simply to DC V if it's digital auto-ranging. Don't start engine, but turn on all lights and accessories, tie the front brake lever back so the brake light is on if possible. Basically, put as much load on the electric system as you can.
Touch or connect the (+) lead to the negative battery post.
Touch the ( - ) lead to the engine and look at the reading.
Touch a bare spot on frame or a bolt and look at the reading.
The engine will possibly be less than the frame reading, but no point of test (from one end of the bike to the other) should ever be over .2 volt but less than .02 is optimum.
Remember, just because an attaching bolt or nut checks good, doesn't mean what it's attached to is getting the same continuity. So be sure to find or scratch a tiny bare spot on the regulator itself.
