So school me.
Old Jul 3, 2023 | 09:38 AM
Hey Man's Avatar
Hey Man
Originally Posted by guido4198
I had been having a sort of "low grunt"...then kick in and start on my '85 FXRS. New battery didn't resolve it. On a hunch...I disconnected the wires at the common ground on the frame. Cleaned and wire brushed the spot on the frame, and each ring terminal. Starts right up now....no "grunts".
Quality of your ground connections is critical on these 12 volt systems.
True. Sometimes people forget that the ground is just as important as the hot.
Old Jul 3, 2023 | 09:39 AM
Hey Man's Avatar
Hey Man
Could timing have any effect on it?
Old Jul 3, 2023 | 10:16 AM
kero's Avatar
kero
sorry
Old Jul 3, 2023 | 10:25 AM
Goose_NC's Avatar
Goose_NC
On my 1989 ElectraGlide, I ran a wire to the feed side of the starter relay. (Not the solenoid.) The stock wiring has the wire feeding the 12vdc throught the marginal wiring hatness. This will ensure enough juice gets fed to the solenoid immediately.
Old Jul 3, 2023 | 10:31 AM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
I think so, but my ignition is timed to the service manual spec, it still grunts on that first push of the button.
Old Jul 3, 2023 | 11:43 AM
Racepres's Avatar
Racepres
Absolutely... Too Much advance and it can stop the starter completely...if ya gots compression.
Can also cause Kick Back and Ruin stuff!!!
Old Jul 3, 2023 | 05:55 PM
bentparts's Avatar
bentparts
Please let us know if you get it figured out. Mine ( 88 FLHS ) has been doing the same thing for years. Also upgraded to new starter, new battery, new battery cables, cleaned grounds etc. Still does it. I also have higher than stock compression with the SE heads. Timed according to the directions that came with the Crane Hi4 ignition, but I think I'm going to try retarding the ignition a degree ot 2.
Old Jul 3, 2023 | 07:05 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Keep in mind that `88 and earlier are a completely different starter/solenoid configuration, however, it does have the same starter pinion/ring gear ratio of 9/66.
Old Jul 3, 2023 | 08:33 PM
86glider's Avatar
86glider
Bentparts : My 86has done it its whole life. Sometimes it spins right off, but when cold , major starter stall.And Ive done exactly the same as you.
Old Jul 4, 2023 | 06:51 AM
Racepres's Avatar
Racepres
Cam???
I ask because different Cams actually cause different Cranking Compression...as does advanced timing..
