New regulator
Old Jul 28, 2023 | 12:51 PM
WP50's Avatar
WP50
It's certainly pointing towards a regulator.
The wire's going from the Reg to the bike harness 2 of them
One goes to a ground point usually to the frame and the other goes to the 50amp main circuit breaker
If all that ck's out good I think a Regulator could be next.
Are you anywhere near Georgetown Tx and indy i know there stocks Cycle Electric stuff.
In the past has been good to still have EVO stuff.
WP
Old Jul 28, 2023 | 01:28 PM
GunnyMo's Avatar
GunnyMo
WP
Hey WP, unfortunately I'm about 3 hours from Georgetown. I'm going to swap out the circuit breaker as a hail mary before ordering another regulator.
Old Jul 28, 2023 | 01:37 PM
WP50's Avatar
WP50
I was pointing out that wire and where it went more to ck the wire out than involve the breaker.
If the breaker was bad you would have a loss of power most everything.
Ck the condition of the connector going to the stator really good. Very common failure point
WP
Old Jul 28, 2023 | 03:06 PM
Dano523's Avatar
Dano523
Stator out put is A/C voltage. Voltage regulator converts that to Dc volts, and send that back to the main fuse on the positive side, and is ground side is bolted to chassis ground termial.
So since you know that the stater has output voltage ( and good to the input side of the regulator), have you made sure that the ground off the regulator is well grounded, and you are checking the output voltage on the main breaker on the positive gold side. Hence voltage regulator goes to gold side, and battery is connected to silver side, down line of the breaker (that may be the breaker itself has gone bad).
https://www.hdforums.com/forum/softa...ocation-3.html
To add, you can go to any autoparts store and pick up a 50 amp main breaker that is the correct amperage and size. If it has the back strap on the breaker, just uses a grinder to break the back strap spot welds to remove the strap, and will fit into the breaker holder on the bike.
If push comes to shove, easy to remove the main breaker metal cover by using a pick tool to push the cap peen sides outwards, to just clean up the contact to the silver post side and heat flex blade, to get it back up and working, them peen the cover back on.
Old Jul 29, 2023 | 05:43 PM
Yankee Dog's Avatar
Yankee Dog
Double check your rubber stator to regulator connector at the engine block. That is a known problem with that rubber stator plug getting soft over time and the pins losing contact. Otherwise, as mentioned double check the regulator is grounded well, then follow the regulator "output" wire from the regulator back to breaker as mentioned, and checking volts. Do the cheap and easy stuff first.
Old Jul 29, 2023 | 06:10 PM
Max Headflow's Avatar
Max Headflow
Make sure the stator is not shorted to ground..
Old Jul 29, 2023 | 11:14 PM
GunnyMo's Avatar
GunnyMo
Good evening everyone, so turns out it was definitely the regulator. Ordered one from Amazon and boom everything checks out. Now to see if I can get a refund for a bad regulator. Thank you all for the input it was much appreaciated. Now to log some miles. See you on the road.
Arjeje
General Topics/Tech Tips
Feb 18, 2016 10:21 AM
96RK
Dec 18, 2011 06:24 PM
hellboyrich
Mar 6, 2011 11:52 AM
bigcity2010
Mar 31, 2010 07:06 PM
93 fatboy
Apr 28, 2009 05:16 PM
