Valve job
Old Feb 22, 2024 | 09:06 AM
lentuk's Avatar
lentuk
Default Valve job
My 99 Heritage has 46000 miles on it, decided to re cam with an Andrews EV27 and some new Hylift lifters, I like to use the stock pushrods so I have the motor torn down so far I am going to hone and ring.
My local machinist retired and I am looking for someone to do the valve grinding, any recommendations for someone local in Southern Ca?
I would not mind sending them off to someone highly recommended by you guys either.
Old Feb 22, 2024 | 10:32 AM
GOGOBECK's Avatar
GOGOBECK
Hammer performance. (208) 696-1250
They are in Idaho, but might be worth the freight.
Their website has a lot of information… check out the tech tips section on the website.
When you do a valve job, you might need to shave the heads to keep the combustion chamber size correct and then you need shorter push rods.
Old Feb 22, 2024 | 12:16 PM
jimkav's Avatar
jimkav
Q&E machine shop in Anaheim
Old Feb 22, 2024 | 03:47 PM
Mountainkowboy's Avatar
Mountainkowboy
Had them do my jugs when I did the topend. I'd let them do my heads
Old Feb 23, 2024 | 07:12 AM
Cobra1's Avatar
Cobra1
Why don’t you just lap them and reinstall. With only 46k I’m sure the sealt are just fine….
Old Feb 23, 2024 | 10:01 AM
lentuk's Avatar
lentuk
Valves and seats are beyond lapping.
Old Feb 23, 2024 | 11:14 AM
Dano523's Avatar
Dano523
Yep, ran into same problem doing a base gasket repair a while back, and was that both seats and valve surfaces where pitted from moisture that where not just going to lap out.
In my case, have tool post grinder set up to re-grind valves ,and valve seat cutter set up to re-cut seats, so don't need to farm the work out.
Old Feb 23, 2024 | 11:33 AM
Rains2much's Avatar
Rains2much
They gave you more local options.. I don’t know anyone that way. But if you mail them, Mike Magaro. Magaro Racing Engines tel:717 561 4255
Old Feb 23, 2024 | 11:52 AM
98hotrodfatboy's Avatar
98hotrodfatboy
If you send the heads out and they resurface them (shave) .040" or more and then add Cometic .030 head gaskets to increase the compression for the EV27 cams I would recommend adjustable pushrods..
Evo91
EVO
15
May 12, 2021 09:14 PM
Farm Shop
EVO
104
Apr 23, 2018 06:32 PM
fergerburger
Shovelhead
Sep 25, 2017 04:33 PM
I8SMK4U
EVO
Mar 31, 2012 06:59 AM
tujo33
EVO
22
Nov 6, 2010 04:36 PM
