Will this idea work?...
Old Mar 26, 2024 | 11:08 AM
tar_snake's Avatar
tar_snake
Default Will this idea work?...
Hiya gang,
This is just a question out of curiosity for the most part.
I still have the frame (no good anymore after I got t-boned by a cager) with the motor and transmission and everything still in my '98 FXD Super Glide.
My plans are to be to save that motor and transmission as backup parts or whole components for my '97 Softail Heritage Classic.
When I went to a dealership sponsored affair the other day, I happened to wander into the 'used' bike room and noticed that have an '07 FXD Super Glide. So, naturally being that I really, really like the Dyna's and truly miss my Super Glide, I was wondering if it's possible (and *EASY*!) to plop the motor and trannie from the '97 into the frame of the '07. Having a backup bike is *ALWAYS* on my mind because all I own for getting around and anything and everything important (like grocery shopping, etc), is my bike, and if it breaks down, I'd basically be screwed until I could somehow afford to fix it (it also makes things difficult being on a fixed income disability check).
Anyway, if anyone has any solid knowledge of the possibility this can be done, I'd sure like to pick your brain(s) for information about it.
Oh, and sorry if this is kinda a disjointed post...I literally just got back from the hospital about an hour ago from having an umbilical hernia operation. I'm in pretty bad pain (hell, my compound fracture of both bones in my left calf after surgery didn't hurt this much!) and on different pain meds and still even a little groggy from the anesthesia, so cut me a little slack, heh heh.
Old Mar 26, 2024 | 02:04 PM
eighteight's Avatar
eighteight
So are you saying the engine in the dealers `07 is dead
Old Mar 26, 2024 | 02:07 PM
Ohio HD's Avatar
Ohio HD
The '97 being an Evo and the '07 being a Twin Cam, the motor and transmission will not bolt in. Anything is possible with enough fabrication and welding. But that would not be easy at all.
Old Mar 27, 2024 | 05:40 AM
tar_snake's Avatar
tar_snake
No, but having owned a '09 and having had nothing but trouble with it even though it got 87,000+ miles, it was nothing but a PITA and always needing something fixed or replaced. It wasn't a very good way to make me want another 96ci bike.
Old Mar 27, 2024 | 05:41 AM
tar_snake's Avatar
tar_snake
That's kinda what I though, but just wanted to make sure. A welder and a fabricator I am not...no imagination. Hell, I can't even draw a stick man straight.
Thanks for the confirmation info.
Old Mar 27, 2024 | 05:44 AM
eighteight's Avatar
eighteight
Your call but buying a cheap used car makes more sense..
Old Mar 27, 2024 | 08:52 PM
Max Headflow's Avatar
Max Headflow
If the complete drivetrain is being used, I wouldn't be surprised if it does fit.. The motor mounts are the same.. 99 FXD used the same swingarm as the 98.
Old Mar 27, 2024 | 09:02 PM
Ohio HD's Avatar
Ohio HD
Max, I'll take your experience with the Dyna models over mine. Isn't there a difference in the swingarm shaft diameter after 2006? If it is as I think, then the transmission case needs modified for the large shaft.
Old Mar 27, 2024 | 11:19 PM
Max Headflow
The swing arm changed in 2006 as did the bolt. Some of it was due to using a spherical ball on the left side instead of a timken. The SW change was likely due to allow for wider tires. Not sure about the shaft diameter. I suspect not as the early ones all had 3/4 inch shafts.
TerryFXST
Shovelhead
Nov 12, 2021 06:51 AM
Daves Deluxe
Dec 11, 2010 12:03 PM
AZ Rider
Mar 13, 2007 01:08 AM
Bubba55
Aug 7, 2006 01:16 PM
56Panhead
Jul 11, 2006 07:34 PM
