stripped tank bolt
Old May 10, 2024 | 11:21 PM
jf7827's Avatar
jf7827
Default stripped tank bolt
I have a 1998 fxstc, split tank. I removed the right tank to work on the carb and when I went to put the tank back on I stripped the rear bolt. I'm guessing I ruined the part of the frame that ya bolt the tank to. what do I do?
Old May 11, 2024 | 05:10 AM
Yankee Dog's Avatar
Yankee Dog
Post a pic. You have options from heli-coil, time-sert, or tapping to next larger thread size. Again, post a pic or a diagram.
Old May 11, 2024 | 08:21 AM
Dr.Hess's Avatar
Dr.Hess
Yeah, helicoil. Done.
Old May 11, 2024 | 08:04 PM
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
Here is another vote for a Heli coil but I'd use some painters tape to mark the drill bit and tap so you don't go too far and drill through the frame.
Old May 12, 2024 | 04:46 PM
Spanners39's Avatar
Spanners39
I used a Riv-Nut on my Shovelhead, worked a treat and better than a helicoil as the frame tube walls are pretty thin and a Riv-Nut adds thickness and threads to the solution.
Old May 12, 2024 | 06:50 PM
Dr.Hess's Avatar
Dr.Hess
I like RivNuts. I use them whenever I need to put something like that through thin wall tubing, fiberglass, etc. I prefer the steel kind over the aluminum. If where you need to fix the threads is not deep enough to hold at least one helicoil, then certainly use a RivNut. Harbor Freight sells a kit, but just with the aluminum ones.
This is the tool you want:
https://www.harborfreight.com/10-in-...kit-58078.html
It will do steel or aluminum. This one:
https://www.harborfreight.com/45-pie...-kit-1210.html
will do aluminum, but is too light for steel work. Mcmaster-Carr is a great source for the RivNuts themselves.
Old May 13, 2024 | 09:53 AM
jf7827's Avatar
jf7827
I have never messed with them before. The Factory bolt (4014W) is 5/16x24 1-1/4. I was looking on amazon. Is this the right thing to get? Need help figuring out "installed length"
E-Z Lok EK30915 Helical Threaded Insert Kit, 304 Stainless Steel, 5/16"-24 Thread Size, 0.469" Installed Length (Pack of 10) E-Z Lok EK30915 Helical Threaded Insert Kit, 304 Stainless Steel, 5/16"-24 Thread Size, 0.469" Installed Length (Pack of 10)
Old May 13, 2024 | 10:09 AM
Dr.Hess's Avatar
Dr.Hess
You will need the right drill bit too. This kit has all of it:
Amazon Amazon
"Installed length" means how deep the insert goes down. I'm not sure what you are putting that in on the frame. How much metal is there on the frame for the bolt to go into?
easystreet13
Sep 18, 2017 07:48 PM
jqb12
Sep 15, 2015 01:21 AM
98Superglide
Dec 3, 2012 08:48 PM
Iron Butt Springer
May 9, 2012 08:57 PM
swomack
Nov 16, 2006 12:44 AM
