Front Caliper Upgrade Question...
Old Nov 4, 2024 | 07:06 AM
  #111
Rains2much's Avatar
Rains2much
I tried installing the brackets to adapt 2000 up 4 piston brakes to my Road king. Everything lined up… but the brake lines coming from the tree down to the caliper are like 4 inches too short. I can’t find any that are longer.
Any ideas? @flhchaz @Trumpet
Old Nov 4, 2024 | 07:20 AM
  #112
flhchaz's Avatar
flhchaz
I'd check out Burly motorcycles web site. They should have what you need
Old Nov 4, 2024 | 07:25 AM
  #113
Rains2much's Avatar
Rains2much
I only see entire kits and no mention of custom or extended length tree down brake lines. Thanks though.
Old Nov 4, 2024 | 07:29 AM
  #114
John Harper's Avatar
John Harper
Call Magnum Shielding, they custom made a brakeline for me. Barnett can probably do the same.
John
Old Nov 4, 2024 | 07:30 AM
  #115
John Harper
Nothing beats a phone call to find out for sure. They may not advertise making custom sets. Don't give up so easily.
John
Old Nov 4, 2024 | 07:44 AM
  #116
WP50's Avatar
WP50
It's been awhile but Barnett made some up for me.
WP
Old Nov 4, 2024 | 09:23 AM
  #117
Rains2much's Avatar
Rains2much
Thanks guys. I just bought custom individual parts. Drag S. TEE, Goodrich Lines… some 90 degree banjos. I got a VM and no answer when I called. But I think it’s sorted.
Old Nov 4, 2024 | 08:55 PM
  #118
GREENOHAWK69's Avatar
GREENOHAWK69
https://spieglerusa.com/brakes/brake...kaAkqbEALw_wcB
I used this vendor for my Ducati and was satisfied.
Old Dec 14, 2025 | 09:58 AM
  #119
crlf's Avatar
crlf
6th Gear
Originally Posted by Spanners39
That isn't a sealed bearing, it's a shielded bearing, designed to catch whatever fluid gets near it and keep it near the bearing surface. Sealed bearings have rubber seals and no way for fluids to get into or out of the bearing....good luck using shielded bearings if it ever rains, or you ever wash the bike....
A forum email reminded me to log in; good times. I had an interesting summer. Ended up riding the Karakoram range in Gilgit Baltistan, with conditions ranging from beautiful paved twisties of the KKH (with the occasional lanslide and devastation from boulders) to miles of babyheads to stream crossings and sheer drop-offs. While the group caught up, got invited into a checkpoint hut for tea with AKs casually stood up in corners of the room. Google the "Shimshal death road" and "Passu Cones" and "Khunjerab Pass" for a look. Breathtaking scenery, getting up close to Nanga Parbat and Rakaposhi as we roamed around. But anyhow, not once was anyone concerned about sealed bearings when crossing streams and pounding over gnarly terrain. There were no mechanical issues of any sort, not even a flat tire.
With a rough estimate of 700 million motorcycles in the world, 99.995% of them rolling on non-tapered bearings, in all sorts of tough conditions, I would suggest that of all the hills to die on, the tapered/non-tapered one is particularly retarded.
Insofar as the "good luck using shielded bearings" well-wishes, first and foremost, thank you. The sort of **** I get up to, luck is always needed and appreciated. The bearing I listed is of the below type, with its sealing method described. Do you think it will withstand a gentle shower? I hope so too.
Old Dec 14, 2025 | 10:42 AM
  #120
crlf's Avatar
crlf
6th Gear
Those are old Adam Sandoval sunglasses, probably the first time Sandoval gear made it into Gilgit Baltistan.
Taking a breather on the Shimshal road.  Best not look down or bounce off the wall.
On the way to the Rakaposhi overlook.  12K feet here?  Who knows.  Easier to breathe compared to Khunjerab at 15xxx feet.
Back home the riding is more chill...
#9 in the world Nanga Parbat, from an alpine valley at 12K feet give or take
Shimshal road toward the village.  Descending from the steep part to ride along the river.
