Front Caliper Upgrade Question...
Old Jul 15, 2024 | 10:55 AM
  #41
98hotrodfatboy's Avatar
98hotrodfatboy
I would like to add that when I had this off the bike elevated up on one of my shelves and bleeding it out with a 5/16 flat bar in between the pads, I noticed that once all bled and fluid was moving properly, that the body of the caliper was actually separating as I would apply force on the lever.. Not sure if that's common with two piece calipers or not but it will actually cause you to lose some breaking on I would think ... Anyways just something I noticed..
Old Jul 15, 2024 | 11:46 AM
  #42
blackjeep's Avatar
blackjeep
I bet it feels a helluva lot better than the original. So far my only complaint with my evo softail.
Old Jul 15, 2024 | 06:43 PM
  #43
Ghetto blaster's Avatar
Ghetto blaster
"that the body of the caliper was actually separating"
Call me crazy but that can't be right, mine doesn't do that, have you tried to tighten the bolts to the caliper body?
Old Jul 15, 2024 | 07:21 PM
  #44
98hotrodfatboy
Let me rephrase, you can see the expansion of the aluminum body when applying a lot of pressure with the master cylinder.. I know what I saw.. There's no leak or anything but you can see the expansion.. You might not see it on the bike but up on the bench you sure can. Even the OEM caliper does it..
Old Jul 15, 2024 | 07:47 PM
  #45
Racepres's Avatar
Racepres
You might be surprised at the PSI being generated...do the Math 5/8 master with ??? how much applied force...to a 2"?? 3" ???cylinder..Lucky it don't break something.. I'm just postulating 5 or 6 times the force being applied!! maybe more...
Edit; Just how much hand strength do you Gots??
Old Jul 15, 2024 | 08:05 PM
  #46
98hotrodfatboy
I Gots Lots......
Old Jul 16, 2024 | 07:19 AM
  #47
Racepres's Avatar
Racepres
I Gots Lots......
Apparently enough to spread the Cheeks.... on yer Caliper anyway!!!!!
Old Jul 17, 2024 | 05:30 AM
  #48
Trumpet's Avatar
Trumpet
@98hotrodfatboy when you installed the cartridges did you use the black plastic spacers? Personally, when I set up my ultra I found that using both of the black spacers on both legs set a firm ride and made the braking fork dive negligible except for worse case 'NOW' stopping.
With the way we're setting them up a bit out of their design envelope some additional shimming maybe be needed, and a selection of thinner ones may help. A friend of mine is machining some delrin spacers in half sizes to that end.
Old Jul 17, 2024 | 05:39 AM
  #49
98hotrodfatboy
One of my spacers broke so I was only able to install 1 per side.. I would love a set of 1/2" spacers.. As soon as I upright the bike off the stand the front end dips immediately.. I think I'll call Progressive to see what they can do .
Old Jul 17, 2024 | 06:40 AM
  #50
98hotrodfatboy
Another thing I noticed was that you need to be careful when installing the lower bolt for the caliper.. Too long and will will contact the rotor.. No it didn't happen to me but just letting others know to reduce any type of damage.. lower bolt length was 1 1/4" with the old thick washer from the top bolt plus one .060" Stainless washer.. It gave me a total of .125" clearance.. And yes absolutely Blue Loctite.....
