Came here to talk about cams
Old Aug 31, 2024 | 08:09 AM
Trumpet's Avatar
Trumpet
On a stock engine with upgraded carb and pipes, any thoughts on the evl3020?
On paper seems like a all rounder cam for street riding. Dyna 1up mostly living in the 3k rpm and up.
Old Aug 31, 2024 | 08:23 AM
Racepres's Avatar
Racepres
The thing is you'll never know unless they do a compression test.. You have no idea what the combustion chamber size is or piston dome volume is.
All I'm saying is without the actual numbers it's hard to really recommend a good cam..
Good Point...There Are good cams for Stock also..but, Gotta Know
Depend on the "pipes" more than Carb.. From My research...if yer gonna live at 3k and Above..EV13.. Or, Jap Bike
Old Aug 31, 2024 | 08:38 AM
Trumpet's Avatar
Trumpet
Supertrapp 2:1. Evos more than happy to play there. Just need a little more for running on the highway.
Exploring cams before I commit to a engine build for the winter.
Old Aug 31, 2024 | 10:32 AM
Racepres's Avatar
Racepres
Seems BassAckwards to me..look for a Cam that Suits your Engine.. How I roll anyway!
If I could Build an Engine around a Cam...I would be Calling Zippers for a Red Shift!!!! Or T-Man
Old Aug 31, 2024 | 12:10 PM
98hotrodfatboy's Avatar
98hotrodfatboy
I would do the W6 before the 3020.. The Traps are a good choice.. 24 plates closed end cap .
Old Aug 31, 2024 | 12:20 PM
Trumpet's Avatar
Trumpet
@ racepres, Then you misunderstand my thoughts.
When sorting the bike two years ago, I added a super e, supertrapp, and dynatek 2000 iggy, all to replace problematic parts already on the bike.
The bike runs well now, and quite healthy to boot, but a little more never hurts?
I am pondering changing the cam, if I can get a good increase where I ride. With stock compression and the upgrades I've already applied seems the evl3020 might be a winner hence the original question.
If not, then I'll choose a different path, 1st being boring 30 over and going 9.5:1 pistons with a new cam and a little head work.
Otherwise, I'll just pull the current mill and drop in a S&S Long block in. Either the v96r or the v111.
Old Aug 31, 2024 | 09:33 PM
98hotrodfatboy
No need to go .030" over.. But I would do at least 10.0:1... Wiseco 12.9 cc dome will get you there and then the W6. With everything else you have it should put you in the low to mid 80's.. Awesome package and will yield over 50 mpg touring with excellent street manners..
Old Sep 1, 2024 | 12:15 PM
Trumpet's Avatar
Trumpet
Thanks 98, I'll dig into this.
Old Sep 1, 2024 | 01:01 PM
98hotrodfatboy
I'm sure there's others that do this build but this was back in the day one of Hillside's trademark builds when all we had was the Evos and the Shovels and it was such a economical power plant.. Not too crazy strong but had everything you really needed to move a 650 lb bike..
Freak Show
2014-2024 Touring Models
15
Dec 2, 2023 09:36 AM
DellMcAlpine
Exhaust System Topics
14
Dec 27, 2013 02:00 AM
bipolarsporty
Aug 18, 2013 10:42 PM
AllenW
Mar 6, 2013 08:19 PM
Chicago Ken
Jan 17, 2012 10:29 PM
