S&S Adjustable pushrod question
Old Jul 19, 2025 | 03:52 PM
Rains2much's Avatar
Rains2much
Default S&S Adjustable pushrod question
Doing a cam swap on a 97 EVO. Owner bought S&S adjustable push rods…. I just noticed there are Quickie, and Standard… that has me Assuming these won’t fit without dropping the motor, gas tanks to get to the rockers?
Looking for confirmation before I go Cowboy… Can the standard S&S adjustable pushrods be installed without removing the rockers? I’m thinking not… and I’ll find out either way in a few.
Old Jul 19, 2025 | 04:53 PM
Bemo56's Avatar
Bemo56
If you use use solid rods, heads covers must come off. I using adjustable only, push rods covers come off. Less work.
Schex's Avatar
Schex
You can install quickies without pulling rockers, S&S standard has to pull them, at least on their 111 it's like that.
Old Jul 19, 2025 | 05:08 PM
nibroc's Avatar
nibroc
^^^^^^^^^^^^^^what bemo said^^^^^^^^^^^^
Old Jul 19, 2025 | 05:30 PM
SparkyD's Avatar
SparkyD
Standards you have to take the rocker covers off. Quickees you do NOT. I learned this lesson the hard way
AND MAKE SURE THE PUSHRODS ARE CLEAR!!!. Blow air thru them before installation. That was another (expensive) lesson I learned the hard way.
Old Jul 19, 2025 | 06:17 PM
Racepres's Avatar
Racepres
I still Do Not understand Cutting Stock Pushrods, I won't.. When I get that Lazy, or Crippled...I will get Help!!
Oh...Unless the Cam is Very Wild..ie, Base Circle has Changed!!
Old Jul 19, 2025 | 07:12 PM
t150vej's Avatar
t150vej
S&S quickie especially and most other fully adjustable push rods create a lot of noise. So, be ready for that.
Old Jul 19, 2025 | 10:54 PM
Rains2much's Avatar
Rains2much
Thanks guys. I did the hole job tonight… yep. Standards, had to pull the rockers. I’ll fire it up tomorrow night. Got the Cam in and everything back together. Just have to install the exhaust and set the timing, put the gas tank back on.
‘Only snags we’re the rockers and shimming the cam and breather.. stupid breather took more shim than usual and the cam took two shims together, I dont like that.
Old Jul 20, 2025 | 08:12 AM
Racepres's Avatar
Racepres
One fat shim is Much better than two thin ones!! and, I don't guess I worry much about Clearance on Breather.. never noticed any Problems..
Edit; Be Very Careful off Cam endplay...Too Tight is Disasterous.. much worse than a Bit Loose.. H-D specified Clearances for a Very Good reason..those who insist Tighter is Somehow Better..Welp..gonna have a Problem!
Old Jul 20, 2025 | 12:08 PM
Rains2much's Avatar
Rains2much
I always like a good 10 thou. It’s at 14 with two thick spacers
and yes, of course I took the recommended 6000 for a crushed gasket into consideration
